  #21
Old 04-30-2010, 05:21 AM
RudiGreyling's Avatar
RudiGreyling RudiGreyling is offline
Originally Posted by Andylaw View Post
Rudi - I have just installed the Mcmaster Carr seals and as far as I am concerned they are far superior to the Vans stock seals. You are welcome to come and look!!
Andy Lawrence
RV 10 South Africa
Fantastic, I want too come have a look!
Rudi Greyling, South Africa, RV 'ZULU 7' Flying & RV 'ZULU 10' Flying
"Science, freedom, beauty, adventure...what more could you ask of life? Aviation offers it all" - Charles A. Lindbergh
Old 04-30-2010, 07:33 AM
Danny7 Danny7 is offline
has anyone used inflatable seals? they are common in the Lancair planes.
nothing special here...
Old 04-30-2010, 05:45 PM
Deems Davis Deems Davis is offline
I had inflatable seals on a Baron, and the McMaster Carr seals, properly installed,are every bit as tight as the pneumatic seals without the cost/maintenance.
I was reluctant to go with these, but having done it. w/ 120 hrs I wouldn't even consider doing anything else.
Deems Davis
RV10 N519PJ
http://deemsrv10.com/index.html
Old 04-30-2010, 07:14 PM
TSwezey TSwezey is offline
I didn't really like the looks of Vans seal at first but we have never had any problems with them.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 05-04-2010, 08:24 AM
yooper's Avatar
yooper yooper is offline
Exclamation Pink and Green
We're going for a combination of Pink and Green diagrams. Namely, not trimming the door frame edge (like Green), but using a one piece modern foam seal (like Pink). Ours will be attached to the door itself.
Aircraftdoorseals.com sold us their standard door seal and after we requested it, some additional material that is a little thinner, for tighter spots.
We'll let you know how it goes when we fly in June . . .
Tim D-T
40025
Old 05-08-2010, 05:03 PM
Ron B. Ron B. is offline
Just about finished , (final time , that feels good) with our doors. They are painted inside and out, the McMaster carr seals are on but not glued. We have Sean's third latch installed (less split pin) in the pilot's door . We still have the plastic catch to mount on the co-pilot's door-sil but it is also mounted for the final time also. The doors are still stiff to close, but make a very tight seal ( at least for now). We are really pleased with the outcome of our door install. The gap all around is fairly uniform, the door is flush with the cabin. They were a lot of work but should be worth it.
Thanks to those that pointed out and providing the part # for the door seal, and to Sean for what looks to be a perfict solution for closing the doors and keeping them closed.
Speaking of keeping the doors closed, how would one escape from an inverted RV-10 (on the ground obviously)? Would you expect to be able to kick out (weld-on and a very thin layer of glass holding them in) the windows?
Ron
Old 05-12-2010, 07:50 PM
ddnebert ddnebert is offline
Default McMaster-Carr seals
I ordered the McMaster Carr seal that has a clip and a side mounted rubber tube, as recommended by others in the forum. I cut it all to size and pushed it on all around the door on the cabin top lip, but in the case of both doors, it seems to push the doors almost 1/4" above the pin latch positions, so that the doors will not close.
Any suggestions based on similar experiences?
Doug.
Doug Nebert - RV-10, #40546 (SB), started 2/2006, low compression O540 with older CS prop, 375+ hours on Hobbs. Flying since August 2010. Based KONP, Newport, OR
Old 05-22-2010, 07:25 AM
Pat Stewart Pat Stewart is offline
Default Door Seal
Last weekend I glued on the vans door seals. Sunday night I took them back off and ordered the MC seal. The vans seal was not good. The MC seals showed up and I have installed them. Fantastic fit and finish, I also really like how the pinch welt closes out the cabin edge. This should be the seal vans uses.
My new problem: Vans seal would not allow my doors to even come close to closing. The MC seals are very close but I am still about 1/8" from closing the doors. I spent a lot of time getting my doors fit and finish perfect. Looks like I will be doing that again. Anyone else have this problem.
Pat
Old 05-22-2010, 02:09 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default All of the sizes will change
when you get your project to your Florida location. The aluminum, the fiberglass and the tires will absorb our wonderful humidity and grow about 10%!
Ron
Old 05-23-2010, 07:21 AM
Pretty hot and humid here in lower Alabama (LA) as well. These doors have turned out to be the most difiicult part of the project.
Pat
