Old 03-26-2010, 07:01 AM
Moura Moura is offline
Default BOSE or ZULU?
Want to purchase a set of headset and am not sure which is best, lightspeed zulu or bose. It will be panel powered. Is there a best one or just a matter of opinion?
Old 03-26-2010, 07:07 AM
unqualified unfluencer
I've used both.
Zulu wins....in price, comfort and sound levels.
Doug Reeves (your host)
Old 03-26-2010, 08:16 AM
9GT's Avatar
9GT 9GT is offline
I LOVE my ZULU!
David C.
Howell, MI
Old 03-26-2010, 08:31 AM
Caveman's Avatar
Caveman Caveman is offline
The wife and I own two Bose and one ZULU. She likes the BOSE best. I have a very slight preference for the Lightspeed. With my set-up the BOSE sets seem to cancel some intercom white noise a bit better. Music sounds better to me over the ZULU. The Zulu seems to stay attached to my noggin a bit better during loops. The Bose may be a tiny bit more comfortable on a long day of flying. Battery life seems to be a bit better with the ZULU. It is a virtual tie for us. Both are great headsets.
A while back someone posted a problem with their BOSE ANR cutting in and out. Mine did that a couple of times and I'm here to tell you it will drive you crazy if it happens. I never found the source as it happened very infrequently. Somebody posted a reply that it was probably cell phone interference and I intend to check that out if it ever happens again. I don't think all cell phones do it, though.
I had a Lightspeed QFR set that I used for passengers. It broke when a Young Eagle tried to spread the earcups apart during very cold weather. I used their "trade up" program to buy the ZULU. It is much more robust than the less expensive Lightspeeds. Now my old non ANR DC Clarks are used for passengers. They work like a TIMEX and just keep on ticking.
Joe Schneider
RV-7, IO-360, BA Hartzell, N847CR
Flying since 2008
Old 03-26-2010, 08:48 AM
odens_14 odens_14 is offline
I've never used zulu but I really liked the bose in the 206 before I sold it. If you decide to go with bose I have a pair for sale here. I've decided to go with the halo's to get another inch of headroom in the -7.
Chris Odens
Alexandria, MN
RV-7 N914N
FLYING!!! as of 7/22/10
Build Log
Old 03-26-2010, 09:08 AM
Jim P's Avatar
Jim P Jim P is offline
So my story.... I bought a pair of Bose X from Pacific Coast Avionics at Oshkosh 2 years ago, but found that they just didn’t do the job in my RV-7 which is a very high noise environment. I suspect that the passive capability wasn’t enabling the ANR to keep up. A buddy had a set of Zulus so we did a side-by-side comparison on a flight and I found that Zulus had much better ANR capability, probably due to the additional passive capability. I found the Bose X to be slightly better in sound quality, a little better in comfort, but a significantly less in noise cancellation ability. After trying the Zulu in flight, I made a run down to Oregon and was lucky enough to have Pac Coast Avionics swap out the Bose for the LS. So chalk up another happy Zulu customer.
I've flown to and from Oshkosh from Seattle area and found the Zulu's to be comfortable enough for some long days in the cockpit. If the noise environment wasn't so bad in the RV, maybe the Bose would be fine, but the Zulu seemed to do a better job in that environment.
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 03-26-2010, 09:17 AM
pierre smith's Avatar
Default I have a Zulu and 3 Bose's in the -10
...and I get to use the Zulu if my wife's not along...then she insists on the Z.
If I had to do it over again...Zulu's for sure, plus they have a Bluetooth input receptacle.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 03-26-2010, 09:26 AM
Bose is very good, I've had experience with it.
Zulu is better, got a great deal on trading up from a broken 20G.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 03-26-2010, 09:29 AM
tdhanson tdhanson is offline
I've only used the Zulu's but I previously asked the same question. I haven't been disappointed. I bought them used. But I will give two thumbs up for their customer service. I recommended the case come with a strap or handle and it turns out they had already upgraded their cases and sent me one 'no charge'. I also didn't get the ipod and phone cord accessories from the 2nd hand seller. They shipped me them no charge. Even though I didn't buy directly from them or from an authorized dealer. Wow. I was pleasantly surprised so when it comes time to buy again... I'll buy from them and recommend any time.
They do have a pay as you go method. It's a substantial down payment and then a pay by the month all with no interest.
Old 03-26-2010, 09:52 AM
uk_figs's Avatar
uk_figs uk_figs is offline
Default I think you have to try them both
I had one Bose and one Zulu, my wife preferred the Bose and I liked the features of the Zulu but I did not like the clamp pressure and the top of the headset is thicker than the Bose which reduced the clearance with the canopy (6ft 3in and -7 slider). I ended up selling my Zulu to a very happy Pierre and bought a slightly used Bose here on VAF. I had the Bose problem of what appeared to be intermittent operation and in my case it was either the earcup coming off the headset or in some cases when you move your head into a position where the -7 cockpit noise seems to overwhelm the mike noise gate.
I had to adjust the noise gate on the SL30 to compensate for the noisy environment.
Net result is I do not think you can go wrong with either choice but personal comfort and preference may cause you to select one over the other so try them both.
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
