Old 02-28-2010, 05:36 PM
tomcostanza tomcostanza is offline
Default Altitude Encoder
I'm about to buy an altitude encoder. I see there is gray code and RS-232 output. My transponder uses gray code, but I notice there are encoders that have both outputs. Why would I ever need RS-232 output? Are there efis units that use RS-232?
Thanks.
Tom Costanza
RV-7A Fuse
Old 02-28-2010, 05:57 PM
Mel's Avatar
Mel Mel is offline
Most of the EFIS and late modern transponders (except for low end) have a serial (RS-232) output. By using this output you only need one wire, whereas gray code uses 10 wires. If you have one of these EFIS and a gray code transponder, you will need a serial to gray code adapter. They usually sell for around $80.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 02-28-2010, 06:37 PM
Transporter Transporter is offline
Default EFIS and Transponder Wiring Example
Adding to Mel's comment...I just wired my Dynon D10A to my Garmin GTX 327 transponder.
The Dynon can output RS232 directly to the GTX327, eliminating the need for an encoder.
or...you can add an encoder and wire gray code from the encoder to the transponder
or...(if the encoder provides RS232 output) you can wire RS232 from the encoder to the transponder
or (as in Mel's example) you can buy a converter to convert from RS232 to gray code to the transponder (for an older model transponder).
Decisions, decisions...
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Old 02-28-2010, 08:24 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
Mike
I have this setup as well.
No need for a separate encoder.
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
Old 02-28-2010, 08:34 PM
Mel's Avatar
Mel Mel is offline
My Dynon D10A feeds altitude to my GTX-320A. The GTX-320A only has gray code input, so I had to use the converter.
Still much cheaper and lighter than a separate encoder.
