  #31
Old 02-16-2010, 12:22 PM
mburch's Avatar
mburch mburch is offline
Originally Posted by Strasnuts View Post
With my new latch system on my airplane, it is IMPOSSIBLE for me to close my door without the pins engaging. Unless you can imagine a pilot that can see 1-2 inches of daylight all around the door seal and takeoff that way??
Seems like it would be even more idiot-proof if the geometry of the gas struts was changed so they're always exerting a bit of force to open the doors... then the door will either be fully latched or fully open (and windy!).
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 02-16-2010, 12:45 PM
rleffler's Avatar
rleffler rleffler is offline
If you install the C-1016 HD 600N HEAVY DOOR STRUT from Vans you will get that desired effect, unless you've put on significant weight on the door from interior finishing.
I've seen this on Geoff Combs' RV-10. The door pops open almost too hard with the heavy duty strut. At the moment, Geoff's door is stock. I don't know if Geoff has done any experiments to see how much weight it will take to make the door rise more slowly.
I would be interested in hearing comments from Deems or other folks that have installed the heavy duty strut.
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 02-16-2010, 03:35 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Had to go to the heavy duty strut
After the interior went in, the original struts would not keep the doors open - went with the heavy strut on one door to try it -- it does open the door vigorously after the initial push and I try to hold it to keep it from banging --- I will put a strap on it so I can let it up gently.
Old 02-16-2010, 10:45 PM
attson attson is offline
Default heavy duty strut
After insulation and leather on the doors the standared strut could not hold the doors up. Order heavy duty strut from Van. work beautifully since
Son Hoang -KWHP
RV10 N172KT
Old 02-16-2010, 11:00 PM
Deems Davis Deems Davis is offline
bob
I've still got the stock struts, I've also got interior upholstery on the doors.
The stock struts will hold the open, but occasionally they require some assist on the way up.
Deems
Deems Davis
RV10 N519PJ
http://deemsrv10.com/index.html
Old 10-02-2011, 02:22 PM
flion's Avatar
flion flion is offline
You know, I never noticed that this thread died, with my question unanswered, and if these have gone into production, I must have missed the announcement. Well, it was a busy year, graduating and all. So, will they work with the flush exterior handles? And, are they being produced or are the plans available?
EAA Technical Counselor #5357
Old 10-02-2011, 03:33 PM
TSwezey TSwezey is offline
I am just curious what door latches were on the RV-10 that crashed in Ohio. Screw the door fire hurts.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 10-02-2011, 03:41 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
http://www.planearound.com/
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 10-02-2011, 09:08 PM
Strasnuts Strasnuts is offline
Default Latch
Still making them....I'm in Salt Lake so you are not too far away. Maybe you can try my doors sometime and see what you think. A lot of them are flying around.
A&P RV-10 Flying 1000+ hours
SuperSTOL Flying 170 hours
Old 10-03-2011, 12:18 AM
dhmoose dhmoose is offline
Default Flush handles?
Thanks for the post Patrick. I just read this thread and researched things last night. It took me a bit to figure out that Sean did begin producing these. To that end, I am ready to place an order. But, the question about flush handles remains unanswered. Sean...can you speak to this? I also have questions regarding the two pin/block configurations you sell. Can you describe the details and reason to opt for one versus the other? Thanks
David Halmos
RV-10
Flying - 570+ hours
Portland, OR
