Old 02-15-2010, 04:50 AM
RudiGreyling's Avatar
RudiGreyling RudiGreyling is offline
Exclamation Brass replacement for Nylon T (Brake Reservior)
RVators,
Can someone please give me the correct ACS part numbers for a drop in BRASS replacement for the Nylon T AND Connectors. During my RV7 build someone posted the wrong info, so I got a set of useless fittings sent to me 1/2 way across the globe to South Africa. On my RV10 I want to correct stuff...
Thanks in advance.
Rudi Greyling, South Africa, RV 'ZULU 7' Flying & RV 'ZULU 10' Flying
"Science, freedom, beauty, adventure...what more could you ask of life? Aviation offers it all" - Charles A. Lindbergh
Old 02-15-2010, 06:34 AM
Sheldon's Avatar
Sheldon Sheldon is offline
What your looking for is called a Male Run Tee... ??
http://www.fastfittings.com/product/18275
Old 02-15-2010, 07:44 AM
TSwezey TSwezey is offline
Don't you have a plumbing supply company somewhere around you?
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 02-15-2010, 08:10 AM
odlee odlee is offline
Default Try an automotive or hydraulics shop.
I went to a local "racing" shop and had custom lines and fittings made. All brass fittings and braided hydraulic hose. Works great and really not that expensive. Has to be less than another special order.
David
