Go Back   VAF Forums > Model Specific > RV-6/6A
Old 02-10-2010, 05:28 PM
JackW JackW is offline
Default Slider Side Skirt Brace
Oracles,
Has any one with a 6 slider canopy tried using the skirt braces from a 7/9 slider?
John Bridges
Riddells Creek (YRID)
near Melbourne, Oz
VH-VNS, RV-6A, IO-320
It flies!
Old 02-10-2010, 06:10 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Originally Posted by JackW View Post
Oracles,
I copied the brace from a 9. Works excellent. Much better than the old method of welding tabs, etc. My canopy is the older round tube type.
L.Adamson --- RV6A
Old 02-11-2010, 03:32 PM
Default Skirt Brace
Thanks Larry, I was thinking of ordering the RV7/9 brace rather than making a similar one. Only difference I perceive is the square tube is slightly larger than the round tube so the angles may not be exactly correct.
John Bridges
near Melbourne, Oz
It flies!
Old 02-12-2010, 01:08 PM
whittfic's Avatar
whittfic whittfic is offline
Default Side skirt brace
I made mine from .040". Not flight tested yet, but seems to stiiffen the sides up nicely.
http://i456.photobucket.com/albums/q...c/DSC03182.jpg
http://i456.photobucket.com/albums/q...c/DSC03181.jpg
http://i456.photobucket.com/albums/q...c/DSC03180.jpg
Clive Whittfield
Auckland, NZ
Old 02-12-2010, 10:00 PM
Frank Smidler Frank Smidler is offline
Default Yes I did
I used the 7 braces on my 6 slider. No issue. The only thing I would do different is move my lock back another hole.
http://picasaweb.google.com/FSmidler...48310227185458
Frank Smidler
N96FS, RV-6
Flying 1/11/09
1085 hr
2WI6 Stoughton, WI
Formally of Lafayette, IN
Old 02-12-2010, 10:13 PM
DENMACRES DENMACRES is offline
Default brace
used a 7 brace (modified) it made the skirts much stiffer. N16DD
Old 02-13-2010, 09:23 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Welded tabs? I'm a bit confused. The responses seem to indicate the stock C-791 canopy side skirt brace was omitted in earlier RV-6 finish kits, at least prior to my kit delivered in 2001. Was the C-791 originally designed for use with the RV-7 slider?
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 02-13-2010, 01:25 PM
L.Adamson's Avatar
Mine was 1996. They hadn't invented the skirt brace by then. Builders were using different methods for bracing, with the tabs being a popular option. I'm glad that skirt braces came out by the time I got around to it. My bottom canopy piece is round instead of the newer square ones.
L.Adamson -- RV6A
Old 02-13-2010, 10:42 PM
rvbuilder2002's Avatar
[quote=Rick6a;405317]Welded tabs? I'm a bit confused. The responses seem to indicate the stock C-791 canopy side skirt brace was omitted in earlier RV-6 finish kits, at least prior to my kit delivered in 2001. Was the C-791 originally designed for use with the RV-7 slider?
The sliding canopy skirt brace was introduced when the finish kit received a number of improvements with the introduction of the RV-9(A) in 1999 (I think??).
Scott McDaniels
Hubbard, Oregon
Old 02-14-2010, 10:23 PM
rv6ehguy rv6ehguy is offline
Default new skirt braces now standard.
Oracles,
Hi John,
When did you get your canopy?
I recieved my RV6A finishing kit early 2007. By then, Van's canopy frame was equipped with square tubing for the side skirts. Also the new C-791 canopy skirt brace was included as well. I made a special die to put shoulders on the lightning holes of the skirt brace. This modification stiffened up the brace and hence the side skirt considerably. Send me a PM (wz_bang@hotmail.com) if you would like pics.
John Van Lieshout
Toronto, Ontario
Canada, eh!
RV6A QB
