View Poll Results: Now that the RV-12 is out the door, what should the next RV be?
Nothing for now - focus on efficiency, cut costs and prices, survive. 209 30.20%
A factory-built version of the RV-12 36 5.20%
The RV-11 Motorglider 120 17.34%
An amphibian 54 7.80%
An updated single-seater 111 16.04%
A twin, using the new IO-233 or Rotax engines 71 10.26%
A turboprop 36 5.20%
A jet! 55 7.95%
Voters: 692. You may not vote on this poll
  #71
Old 01-21-2010, 05:07 AM
flyboykelly's Avatar
flyboykelly flyboykelly is offline
I'd like to see a fast back option on the RV-8 and for the company to just survive. Too many kit manufacuring companies have gone out of buisness going down the road of too many airplanes too fast.
Flying as of 1-12-2016!!!!!
Old 01-21-2010, 08:26 AM
Low Pass's Avatar
Low Pass Low Pass is offline
What should they do? Take a break and go fly!
Then come back and keep doing a great job of providing a very high value product. The more RVs out there flying, the better off we (GA) all are.
Bryan
Houston
Old 01-21-2010, 09:15 AM
rph142's Avatar
rph142 rph142 is offline
VTOL single seat air to air refueler bush plane on floats. They would have the market cornered.
Rob Holmes
www.myrv3.com
N59LG
The minimum number of planes one should own is one. The correct number is n+1, where n is the number of planes currently owned. This equation may also be re-written as s-1, where s is the number of planes owned that would result in separation from your partner.
- Veluminati
Old 01-21-2010, 09:19 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default You forgot to mention the
Diesel engine
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-21-2010, 09:41 AM
MSFT-1's Avatar
MSFT-1 MSFT-1 is offline
Default I recently saw a Tecnam P2006T Twin
It is a certified airplane, but it has some pretty interesting characteristics:
Twin Rotax 912 (100hp each)
145kt true cruise speed
10gph total at cruise on autogas
About $500k.
Admittedly this is not the right price range for most successful homebuilts, but it shows that a twin Rotax setup is doable.
Bruce
Richmond, VA (KFCI)
RV-10 (520+ hours since first flight in Nov 07)
RV-8 (500 hours, sold Sept 07)
Old 01-21-2010, 10:18 AM
breister breister is offline
About $500k.
Here is a twin-Rotax kit plane that beats the Tecnam in every way, and for more realistic home-built prices.
Aerocat Amphibian
On this design you could easily substitute a pair of WAM 120s or Gemini 100/125s (if they are actually in production), or the less expensive 135 HP Jabirus as well. There are lots of engine choices at the low end of the power spectrum...
Old 04-17-2010, 10:23 AM
Bugs66 Bugs66 is offline
After reading several articles on the Tecnam P2006T, I think this would be an ideal setup for a kit plane. I bet Vans could easily design a platform for dual Rotax's. A twin for the masses! That's my vote.
Old 04-17-2010, 12:17 PM
w1curtis's Avatar
w1curtis w1curtis is offline
Many of these choices (A twin, using the new IO-233 or Rotax engines, A turboprop, A jet) are incongruous with Van?s philosophy ? simple, efficient, cost effective.
How about certification of the RV-10! Every time I fly the RV-10 I?m amazed how much they ?got right?, its efficiency and performance. This did not work out so well for Lancair/Columbia but their philosophy is soooo much different from Van?s.
For now though I think he should ?go to Disney world.? When he gets back, update the 7/8/9 kit plans to the same format as the 10 & 12, then he can start looking into certification of the 10 to compete with Cirrus, Cessna, et al.
William Curtis
SB RV-10 40237, Status, Panel, Engine, Paint, Me, NE RV-10 Page, Cessna 177RG, AF Missions
?Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.? - Dr. Suess
Old 04-17-2010, 12:33 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
I agree with W1Curtis. Take a break. Travel a bit. See the country. Smell the roses.
Then fix the plans. I am helping a guy with an RV-8A quickbuild and looking at the fuselage part of the plans it will take a lot of time to understand what to do.
Old 04-17-2010, 05:12 PM
rvbuilder2002's Avatar
It must be an older vintage kit. The 8 (and 8A) plans issued with all fuselage kits since the -1 kit came out (about 4 years ago) have a point in the manual that says "If building from a Q.B. kit start here" (or something like that).
Scott McDaniels
Hubbard, Oregon
