Old 01-08-2010, 06:34 PM
RV8R999 RV8R999 is offline
Mel - are you kidding me? A DAR can require something that is not required through regulation simply because He/she thinks it is safer? I think I'd have to challenge any DAR directly on that count. Don't they have to inspect to some standard not opinion, especially in this case in which the FAR's are specific enough?
Ken
Old 01-08-2010, 06:37 PM
in the name of safety is an awfully big umbrella...
Old 01-08-2010, 06:42 PM
ronschreck's Avatar
ronschreck ronschreck is offline
Angry They don't even have real whiskey in them!
I stuck a whiskey compass on my glare shield with double sided tape and removed it as soon as the DAR was out of sight. The GRT magnetometer works just fine and the GPS course indicator is close enough to use in the unlikely event of magnetometer failure, and it is certainly more accurate/useable than a whiskey compass.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 01-08-2010, 07:01 PM
Mel's Avatar
Mel Mel is offline
Default Not Kidding!
Ken
A DAR or FAA ASI can require anything he wants. Of course if he get very far out of line, he will stop receiving applications. Believe me, word gets around fast.
One example; Typically when I do a pressurized aircraft, the cabin pressurization tests have not been done. In this case I will issue Phase I only and require another inspection after the interior has been done and the pressure vessel has been properly tested. The reason for this is that an upholstery screw can totally destroy the integrity of the pressure vessel.
Another example: I require flexible FWF fuel lines to be fire-sleeved. The regulations for experimental aircraft do not require this, but I consider it a "safety of flight" issue.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 01-08-2010, 07:02 PM
Sam Buchanan's Avatar
Sam Buchanan Sam Buchanan is online now
been here awhile
My RV-6 had an automotive compass suction-cupped to the windscreen (just) for it's inspection (1999).........
The RMI uEncoder magnetometer was the real magnetic indicator (probably looked at it no more than a couple of times before it was removed a few years later).
Sam Buchanan
RV-6
Fokker D.VII replica
Old 01-08-2010, 07:07 PM
Mel's Avatar
Mel Mel is offline
Default YEP!
I've been there. As a matter of fact, my Moni Motorglider kit came with a $1.99 Wal-Mart compass, suction cup and all.
Old 01-08-2010, 07:26 PM
N941WR's Avatar
N941WR N941WR is offline
Velcro for me Ron. I have since passed the compass on to Doug Reeves for use in his RV-3.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-08-2010, 07:35 PM
dhammer's Avatar
dhammer dhammer is offline
Originally Posted by SteinAir View Post
PS, Bill...which airliners do not have compasses in them? Personal curiosity! I figured the 787 and the new Sparky's (Airbus) are some of the most advanced out there....and they have a whisky compass in 'em.
Don't know about any airliners on that, but Gulfstreams from G4 and up have DMDI's and no whiskey compass.
Don
Old 01-08-2010, 07:58 PM
Mel - do you, or would you, provide your personal requirements ahead of the inspection if the builder asked you in an attempt to avoid a denial of the airworthiness certificate? Do you think most DARs would be willing to do so?
I guess I wouldn't have a problem with a non-req fire-sleeve requirement as long as I knew it was expected and had time to install them prior to the inspection (although I planned on doing this anyway - this weekend in fact). This seems like a reasonable working relationship between builder and DAR. However, if the DAR shows up and says, "surprise, you should have installed a ballistic parachute cause I personally feel this is a safety of flight requirement" I might rather abruptly show him the way out of my hangar
Old 01-08-2010, 08:09 PM
Mel's Avatar
Mel Mel is offline
Yes. I have no problem making my requirements known prior to inspection. There are very few things that I "add", like the firesleeve. And if the DAR is uncooperative, I sincerely believe that he will not receive many calls.
I've been doing this for over 10 years and only had one person who didn't want to install firesleeve. After discussing the matter, I finally convinced him that it really should be there.
BTW, firesleeve IS required on all part 23 aircraft.
