12-28-2009, 01:33 PM
Originally Posted by Jamie
I had the same thought but after a second look I realized that this is an old thread from 2005 and likewise George's post was from 2005. I miss George's posts.
And I couldn't figure out how Bob Axsom's plane was only flying a year and a half. Thought I was delusional.
L.Adamson --- RV6A
12-28-2009, 02:22 PM
Since the thread is alive again Ill ask the question, why cant the breather tub be ran into the air filter box and any oil would be sent back into the engine and burned, I know it cant be done just curious to why it cant.
12-28-2009, 04:03 PM
Jeez...you're right. Shows how much attention I paid - I was just so surprised to see a post from George that I didn't even look! I guess Larry was right, the dead giveaway should have been Bob's plane. Heck, he's been through about 118 airframe modifications/revisions since then!
As to running it into the airbox, I can think of a number of reasons I wouldn't want to do that....basically it'd make a mess. I don't know if it'd affect the venturi in a carb, but the impact tubes/diaphragms in an injector servo certainly wouldn't like it.
Stein
12-28-2009, 04:10 PM
What you're thinking about is "positive crankcase ventilation" or PCV. It works fine on cars. BUT, it has to be designed in.
Simply sticking the vent line back into the carb intake doesn't work.
And like Stein says, It would make quite a mess.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
12-28-2009, 04:26 PM
Don't anybody look, but this is one of the signs of a nearly mature network or community, when a thread (,concept, idea, interaction, useful nugget) from four years ago can come back to life as if it never died. Ok, I used to be an AI junkie... This is a great thing as far as I can tell. The database is critical. I know Doug is aware since HE owns it! Long live Doug (and Audrey?) and his allowing us to use HIS database freely.
Scott Card
CMW E-Lift
12-28-2009, 04:37 PM
OK, my 2 cents on feeding the vent to the air box...
...don't do it. The air box "sees" a positive pressure due to the ram effect of the cowling design. This positive pressure is good from a performance / hp point of view, but is not desirable from a crankcase pressure point of view.
The crankcase needs a slight "negative" pressure that vents the crankcase "vapors" overboard, and this negative pressure is not always available from the airbox.
12-28-2009, 05:55 PM
not airplane related
No hijack intended! The breather froze up on my generator engine while being run in the winter. The pressure blew out the dip sick and eventually all the oil. My first clue, inside the house, was when the power went out due to the connecting rod seizing to the crankshaft. Luckily the rod is aluminum and the crank steel. Clean up the crank, new rod and back in business.
Made me appreciate the value of the extra hole in the airplane breather tube!
12-28-2009, 10:32 PM
Cut mine today
I was up at the hangar today and cut the whistle slot using a dremel. I used a small flat head screwdriver to try and bend the top side of the slot in, but now the opening looks kind of wide. I put the slot up fairly high on the breather tube. Should I be worried about venting oil inside my cowling?
Craig Schwartz
RV-8 (Flying!), IO-360B1PC2 (180 hp, 1 P-Mag, 1 Slick Mag), Whirlwind 200RV, AF-3500, G496, Digiflight II, Classic Aero Sportsman Ultraleather Seats
N868RV
Santa Rosa, CA
12-29-2009, 08:20 AM
why the whistile shape?
What is the theory behind the whistile shape? Woudn't a simple hole or slot work just as well?
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
12-29-2009, 08:35 AM
Might be needed
A friend of mine co-owned a Cherokee-6 in MN a number of years back. His partner took off one day and had oil on the windscreen. He found his dip stick had popped out. He re-inserted and flew again with the same results. He then wired the dip stick tightly in place and left on a trip. The front seal failed and an off airport landing resulted with damage. Of course it was a frozen crankcase vent tube.
BTY, what happened to George? Will he ever be back? Is he banned? He certainly livened up the forums.
Mark
Mark Strahler
RV-6 (Purchased flying)
KFFC-Peachtree City, GA
