Flew with the straight through Plantronics today. (Mic without bias, ring NC.)
Was pretty awesome actually. I don't think I can ever go back to a headset... much quieter than my old Peltor's. Audio quality was superb. Mic seemed to work well on radio transmit. Seems like the "head footprint" is less than the Halo or CA's with no "wire" or "headset" and with the Comply tips I think they might even stay in place during light acro -- just make sure you squish them real good before putting them in. I wanted to keep talking to ATC just because...
HOWEVER, the intercom didn't work so well...not a squelch issue, but I have to talk very loud and steady. I'm going to try to add a battery powered mic bias and test again this weekend. But, solo, it was perfect.
This is what I used, from Amazon:
Plantronics 480 ($20.44 shipped)
Comply T-400 Tips ($14.95 for 3 pairs)
And from
Mouser:
1x
Small Case ($2.96)
2x
3.5mm Jack ($1.29)
1x
Red 1/4" Audio Plug ($6.90)
1x
Black .206" Mic Plug ($9.02)
...I swapped the red/black cases so the mic was the red jack. Also picked up a stereo "extender" cable locally so I could find one in-person with a good feel...nice flexible but tough 1/4" cable. Cut the ends off and in half to use for the "to plane" wire. Other than that, just drilled the case and soldered the wires to the jacks and plugs. (I didn't have a spare headset to use, and since the Plantronics 480 is a little delicate, wanted to be able to use it without modification...and build an "adaptor box", which could also work with any other PC headset too. I'll probably order two spares in case they become hard to find.)
I actually got 3 mini jacks, so I'm going to use the 3rd as an input for a battery back with a variable bias resistance and voltage to the mic's ring contact so I can experiment with the best mix for radio and intercom use (if it helps at all...). Will post what happens...and document the wiring if it works well.
All in, less than $65. =)
