Old 12-27-2009, 01:41 PM
Originally Posted by DanLandry View Post
They built my fuel tanks after my first botched attempt.
He really has the system down. Nice clean application of proseal and no leaks.
Sorry to hear about the bird strike but it could have been far worse for sure, like through the prop or canopy.
Dan, about the Evan's tanks, how did you match drill the Z brackets to the spar shear web or was your wing still open?
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 12-27-2009, 04:03 PM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
Hey Brian,
I'm at Caldwell, too...I don't think I've ever seen your airplane. Where are you parked? If you don't mind, I'd like to come take a look one of these days. I'm close to the cafe.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 12-27-2009, 04:33 PM
hydroguy2's Avatar
Originally Posted by lostpilot28 View Post
..... I'm close to the cafe.
aah, yes the Airport Cafe. if you leave there hungry, it's your own fault. I need to go back.
Old 12-27-2009, 10:35 PM
wizard wizard is offline
Default Matching question
That's a good question about the matching. IIRC, don't I have to match drill the Z-brackets through the spar to ensure that the tank lines up correctly?
Sonny...sent you a PM.
Brian Hansen
Eagle, Idaho
RV-7A N887BH - SOLD
Old 12-28-2009, 07:33 PM
dekky111 dekky111 is offline
Default New Tanks
Do have a set of tanks for sale. 117 hrs on the plane prior to the 'incident'.
Let me know if interested.
Jack
dekky111@gmail.com
Old 09-19-2010, 05:41 AM
apkp777's Avatar
apkp777 apkp777 is offline
This happened yesterday on my first ever Young Eagles flight. It was impossible to be angered when you have such smiling faces all around. Fortunately mines not as bad as the original post. Did you rebuild your tank? I should be able to reach in from the tip and bang mine out with some body and fender tools. There's a bit of a crease at each of the adjoining ribs. Those might take some filler. Of course Aviation Simple Green will get rid of the blood.
[IMG][/IMG]
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 09-19-2010, 09:43 AM
Tony,
I'm sorry to see that! Fortunately for you and your passenger, it could've been much, much worse. Overall, I'd say this looks like a "mild" bird-strike. Either way, the damage is done and you need to fix it.
The question I have is how big was the bird? I often see hawks flying around locally and I would think they would put a hole in the wing if someone hit them.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 09-19-2010, 11:45 AM
Geico266's Avatar
Geico266 Geico266 is offline
Sorry to see the damage! That must have been a big bird!
I had a bird strike in the -12, but it was on take off and the hit was right on a rib. Not even a dent. The bird left skin and feathers though.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 09-19-2010, 11:49 AM
apkp777's Avatar
It's hard to say what the size of the bird that hit the wing was. Seems every northern bird was on it's way to the south for the winter yesterday. I think I saw more birds heading south yesterday than any other day I can remember. All I saw was a black flutter, then a thump. Probably a small bird as I am pretty sure there'd have been lots more damage otherwise. I thought about landing in a river, maybe I could write and sell some books or make a movie.
I think I was indicating about 130 KTS at the time of impact. After I landed I asked my little Young Eagle if she had a good time. She was thrilled and was all smiles. Worth all the dented aluminum on my plane.
Tony Phillips
Old 09-19-2010, 01:41 PM
Snowflake's Avatar
I hit a seagull once in my parents' Cessna 150... A flock of them flew up in front of me as I was approaching the airport one day. It hit the wing on the pilot's side, glancing off the top surface, but I had no idea where it hit. I just heard a loud "BANG" that really sounded like it came from the tail... I guess the tail cone made the noise reverberate more than the impact on the wing.
I flew straight and level for a second while I looked at every surface I could see, but couldn't see anything. Controls check said everything worked fine, so I came in and landed. We hunted all over the airplane, mainly focussing on the fuselage and tail, before I found the dent while putting gas in. It looked like Tony's dent above, but with no blood smear.
A witness on the ground said he saw the bird fall after I hit it. I keep meaning to put a kill symbol on the side of the cockpit but I keep forgetting.
Rob Prior
