Old 12-06-2009, 05:10 PM
6S4 Hugo's Avatar
6S4 Hugo 6S4 Hugo is offline
Default Ramp Checks for Gimps?
I have a "friend" who is pretty gimped up and must use forearm crutches to get around. My "friend" has a question:
He'd really like to get back into flying and he's very interested in the RV-12. If he was flying and landed and got out with crutches, could the FAA guys do a ramp check and determine him unfit to fly?
Sport Pilot lets us Self-Certify...but if there is an obvious physical problem, could my "friend" get his ticket pulled?
Background: He still walks, drives a manual transmission very well and otherwise is quite able to get around. The deficit is primarily on his left side.
Old 12-06-2009, 05:13 PM
trg 854G trg 854G is offline
Does he have a valid driver's license? Any restrictions on the DL?
trg 854G
Old 12-06-2009, 06:32 PM
6S4 Hugo's Avatar
Valid D/L and only restriction is same for all us "old farts":
"Must wear corrective lenses"
He just finished a drive of over 4,200 miles...the last 3,300 was towing a trailer. Except for the blue "gimp sticker" in his window, you couldn't tell anything was amiss.
Old 12-06-2009, 06:39 PM
dhall_polo's Avatar
dhall_polo dhall_polo is offline
Default Ask Jessica Cox
Woman Born With No Arms Becomes First Pilot to Fly Airplane With Feet
http://www.foxnews.com/story/0,2933,463368,00.html
inspiring...
Don Hall
N517DG - RV7 - Flying!
Ticked Van's Hobbes meter at #6110, 3/7/09
Old 12-06-2009, 06:43 PM
flyeyes's Avatar
flyeyes flyeyes is offline
I have a friend who uses crutches after a neck injury, but has a clean medical that he acquired after the injury. IIRC he had to take a checkride (in a Beech Musketeer) and after demonstrating that he could fly the unmodified Beech got his ticket.
There are a number of "wheelchair" aviators that require modified controls, but they also have medicals.
My point is that AMEs don't do ramp checks. This is a non-problem
James Freeman
RV-8 flying
Old 12-06-2009, 07:01 PM
terrykohler terrykohler is online now
Default There are still restrictions
The pilot must be "not known to have any medical condition that would make that person unable to operate a light sport aircraft in other than a safe manner". Physical disabilities can be adressed with a letter from a personal physician clearing us for driving and flying. While it's my understanding that an agent of the FAA may take action pretty much any time they want, carrying such a letter along with your Drivers License and Sport Pilot Certificate should help prevent the problem you suggest.
Terry, CFI
RV-9A N323TP
Old 12-06-2009, 07:15 PM
Default FAA Does Ramp Checks
Jim:
You are correct in that AMEs aren't doing spot physicals on airport ramps. The physical waivers you refer to are called SODAs (Statement of Demonstrated Ability) and are used when those of us with medicals (non-sport) don't meet required physical parameters or have some sort of disability. IIRC, applications for a waiver is made to OK City, and the testing/ demonstration is done at your local FSDO.
Terry, CFI
RV-9A N323TP.
Old 12-06-2009, 10:13 PM
Danny7 Danny7 is offline
inspiring...
I don't think that exactly relates, i believe she is only signed off to fly the ercoupe because of the control mix, ie it doesn't have foot pedal controls.
nothing special here...
Old 12-06-2009, 10:48 PM
jjconstant's Avatar
jjconstant jjconstant is offline
Default double above the knee amputee
I have a friend who is an double amputee who built and flys both an RV4 and RV9A. He uses forearm crutches and removes his legs and uses connectors of his own design to hook himself up to the pedals to fly. I believe he had to do a checkride to demonstrate ability and he built special devices into his aircraft to deal with rudders/braking etc. Both aircraft are certified regular homebuilts, not sport pilot/LSA type planes.
He and his RV4 were on the cover of the EAA magazine acouple of years ago...hence his RV4's name: Cover Girl
Jeremy
Old 12-06-2009, 11:17 PM
N526JS's Avatar
N526JS N526JS is offline
Default I'm a gimp.
I guess I am a gimp. I have a below the knee amputation on my left leg. Motorcycle accident, another story. No problem flying my C-182. Don't expect any problem with my 9-A when completed. SODA (Statement of Demonstrated Ability) says "Must wear artificial limb". Yes, the medical says "must wear corrective lenses" as well.
