11-28-2009, 01:07 PM
Catto prop RPM
Today while flying at 8000 ft I leaned for max RPM it was 2747 at full power.I have a 3 blade catto on IO360 with cold air ind. ,LASAR ign. AFP fuel inj. and high comp. pistons . Anyone with a like set up what is your max Rpm? I think it should be 2850 !!!!!
Jim Gallaway VAF#782 2013 PAID 2014 paid
Gundys airport
Owasso,Ok
RV8A N184JG FLYING SOLD
RV7 N1717G FLYING sold
11-29-2009, 07:45 AM
What is the pitch of your Catto prop?
11-29-2009, 11:20 AM
3 Blade 66X78
Gundys airport
Owasso,Ok
11-29-2009, 02:20 PM
What you are getting sounds about right. For a data point- I have the same prop but with 76 inch pitch. RV-6/ Superior O-360/ stock setup with one LSE ignition. At 8000 leaned for best power I see in the high 2700s to around 2800. I had Craig make my prop slightly under-pitched for my setup so as not to loose as much low-end performance.
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
11-29-2009, 09:32 PM
I'm running the Superior IO-360, fwd induction, dual mags, 3blade 66x76.
My max rpm range is 2650-2680 @8000.
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
11-30-2009, 03:03 PM
I am running the Catto 66x76 on my Eci 0360/180 with a LS PIII on one side and a mag on the other. At 8000 density and leaned for max rpm she is knocking on 2800 rpm. At lift off here in Prescott (5K+ feet elevation) she is turning between 2200 and 2230 rpm.
Hope this is of value.
db
Dave B.
RV9a/ECiIO360/James Cowl/WW RV200 Prop
Flying since 3/06 and still smiling!!!
11-30-2009, 04:14 PM
db
What kind of speed????
Gundys airport
Owasso,Ok
11-30-2009, 05:34 PM
db
Can a Sam James cowl + electronic ignition buy me 1000rpm?
I haven't tested this in almost 3 years. I'll go flying this weekend and get some new numbers. I was going by old notes on 3 way flight testing.
All my xc have been lop in my sweet spot.
1190+ hours
2019 Donation Paid
12-01-2009, 07:40 AM
Hi Jim,
It has been a long time since I did any speed runs at 8k density. I normally cruise this airplane at 60-66% power (my sweet spot) and see, depending on altitude (higher with the 9 wing is better) 162 to 166 tas. The last wide open run at 8k density, using a 4 way gps track and Kevin H.'s spread sheet gave me around 176+ tas.
Dan, I bet the EI and James would give you 100 additional rpm.
db
Dave B.
12-01-2009, 08:25 AM
Catto RPM
Hi All
I just had Craig Catto re-pitch my 3 blade prop. The new numbers are
2700 rpm max WOT leaned to best RPM's thats all I could get at 8000' 177kts on the gps with a three way average.
O320E2D lyc w/2 Emags and 8.5 to pistons
Dayton Murdock
VAF#408 RV4 N359DM Flying 1046 hrs 7/16/19
Builder Log
