Old 11-07-2009, 07:49 PM
sneedrv-6 sneedrv-6 is offline
Default DigiFlight II VSGV
I have a DigiFlight II VSGV.Just got it back from the company with the update to allow it to work better with the advanced flight Efis. Today I noticed that in level flight with the AP on say at 6,000 feet if I put my finger over the light sensor of the AP head that auto dims the face of the AP the plane climbs about 400 feet. Remove you finger from the light sensor and the plane drops back to 6,000. It started to really get interesting when I was flying an approach (gps) and removed the black electrical tape from the light sensor, you guesses it, the plane dove 400 feet. I'll be call TT Monday but thought I would post this to see if anyone else can test and I think this could be a safety issue.
Jason
RV-6 Dual AHRS Advanced Flight.
430w
AP is vertical and horizontal
Awesome aircraft photography!
Sneedimages.com
Old 11-08-2009, 06:06 AM
vandi vandi is offline
That sounds like a really nifty "feature" to have...
good luck!
Brian Vandivier
VAF #2581
n72bv <---- reserved
RV-12 Starting soon Partially built 2nd hand empennage kit -- 1st accident 11/24 transporting home.
.........Totalled truck and significantly damanged trailer. No damage to aircraft parts...
RV-10 in the long range future
Old 11-08-2009, 06:09 AM
Geico266's Avatar
Geico266 Geico266 is offline
I cannot imagine how the light sensor (to dim the screen) could possibly be linked to the ALT hold or rate of climb. This is gonna be interesting! Keep us informed.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 11-08-2009, 07:17 AM
flyvans.com flyvans.com is offline
is this with the new display (blue) maybe?
or still the old one (greenish)...?
given the fact, that there is a history of EMI problems, that could only be rectified using an external db-25 filter (been there, done that) i can certainly imagine something like this happening...
will be very interesting to see wheter anyone else reports the same problem/can reproduce it.
kind of proves my (general, not a/p or trutrak related) experience that the actual wiring itself is easy. the problems appear with EMI, RFI, incompatible serial links and other undocumented stuff similar to this.
keep us updated!
rgds,
bernie
Bernie Daenzer, Alex Lichtensteiger
www.flyvans.com
RV-7A
S/N 72072, Flying!
HB-YMT (Switzerland)
Old 11-08-2009, 07:36 AM
Default Blue Display
It is the new updated head with the blue screen. I also shot video.
Jason
Old 11-08-2009, 09:05 AM
i suggest (if not already done) to contact lucas at trutrak and maybe post in their forum as well...
sounds like a bug could have been introduced by the new display...
was about to send in ours for the upgrade, but may want to sit this one out first... thanks for the info.
bernie
www.flyvans.com
RV-7A
S/N 72072, Flying!
Old 11-08-2009, 10:07 AM
Bavafa Bavafa is offline
shucks, I just sent mine and expected to get it tomorrow. I sure will be testing it to see if mine will do the same. Thanks for the heads up!
Mehrdad
RV7A - IO360M1B
Old 11-08-2009, 10:59 AM
breister breister is offline
Nuts is right - mine is likewise meant to undergo surgury tomorrow!
Question for the OP - do you have the filter on the back that was recommended for those of us who experienced transients when keying the mic? This symptom sounds similar to the "mild" version of that glitch.
Old 11-08-2009, 11:13 AM
Can any one elaborate a bit more on the filter or DB25 as what it is and what is it suppose to do? Sorry if I sound ignorant in this regard, it is because I am
Mine had the green screen which went out twice but it always functioned properly no issues with mic or auto dimming function.
Regards
Mehrdad
RV7A-IO360M1B
P.S. What version of software do you have now that is misbehaving?
Old 11-08-2009, 11:35 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default New Screen
I've flying mine with the new blue screen for a couple of weeks. I need to contact Lucas tomorrow as well. My unit has been shutting off under bizarre circumstances. I have had it shut off when changing frequencies, when I covered the light sensor and hit the PTT button. I've been able to duplicate this after suspecting a problem. Seems to be sensitive to any electrical changes.
I love the blue screen and I'm hoping this is minor issue that can be quickly resolved. I'm confident in TruTrak.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
