  #101
Old 04-21-2009, 04:03 PM
paul330 paul330 is offline
Thanks - I intend to have it done in something less than that!
I'm heading back UK-ward today so I'll post a close-up later with some construction guidelines for the cradle.
Not too long now until I'm up to my armpits in Proseal..........
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
2019 Donation Made
Old 04-24-2009, 12:44 AM
Default Wing Cradle
As promised, details of the wing cradles. I don't take credit for the idea which has been previously documented in these forums. However, the ones I have seen have been full length and somewhat unwieldy.
The root end sits on a sawhorse.
Make a base frame - I used planed 3x2 all round. The internal width needs to give 2 11" gaps with the 3 uprights - this worked out at 30". Make the frame about 3ft long. Fit wheels.
Make 3 upright frames to fit inside the base. The top should be 1" lower than the sawhorse. Add 2 cross braces 18" below the top. Obviously make sure everything is square.
You will need a piece of scrap carpet about 3x8. Trim it to width and tack it to the centre frame - I used broad head roofing tacks. Clamp in approximately the right position to the outer frame. Position the wing in the cradle and pull the carpet tight so the wing sits snug and level. Tack to the outer frame and trim.
I suspect the sawhorse is going to have to go and a second cradle made when I fit the fuel tanks.
Paul
2019 Donation Made
Old 05-03-2009, 11:18 AM
jtrollin jtrollin is offline
Tail cone done!!! Started the work of attaching the elevators to the HS today. I am getting real tired of taking the elevators on and off, but the ratcheting wrench I bought was a life saver. My trailing edges of the elevator are perfect, but one of my trim tabs has about a 1/4 inch warp to it.
http://rv10.trollingers.com/gallery2...serialNumber=1
now to go remove the elevators again...
John - Leesburg VA
RV-10
http://websites.expercraft.com/jtrollin/
Phase 1 Complete
Vans Builder Number: 40923
798HJ Reserved
Old 07-26-2009, 12:08 AM
Janekom's Avatar
Janekom Janekom is offline
The big Lycoming IO-540 is now where it belongs
Jan Hanekom
South Africa
Approved Person nr 325
http://www.rvbits.com
RV10 - ZU-XOX - (Flying)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Bought back)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2020 WITH A SMILE
Old 07-26-2009, 01:02 AM
RudiGreyling's Avatar
RudiGreyling RudiGreyling is offline
Looking good Jan!
Rudi Greyling, South Africa, RV 'ZULU 7' Flying & RV 'ZULU 10' Flying
"Science, freedom, beauty, adventure...what more could you ask of life? Aviation offers it all" - Charles A. Lindbergh
Old 08-08-2009, 07:58 AM
Janekom's Avatar
Top cowl fitted and while I was crawling around, I thought this will be an unusual picture of the engine.
Then I have also fitted the bottom cowl today. Note the wooden disk I have made in place of attaching the prop with spinner backplate. Lots of room to work now! And np prop streikes on the head either.
Jan Hanekom
South Africa
Old 09-01-2009, 05:29 AM
Default Rudi on 100Hours
RVators,
my first progress report on VansAirforce, and I just gone through the 100hour mark, and managed to complete the V-stab, Rudder, and H-Stab so far.
This RV10 is MUCH larger than my rv7 and/or rv12 I played around with before
Regards
Rudi
Old 09-01-2009, 07:14 AM
TSwezey TSwezey is offline
Rudi I hope the -10 won't limit your trip reporting.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 09-06-2009, 09:13 PM
flion's Avatar
flion flion is offline
Default At last!
Well, a couple of weeks ago I finally broke down and started the -10. I'd been trying to get a truck restoration project out of my hangar (still trying; I'm just working around it for now) before I got started. Anyway, I've got the VS and rudder done (rudder pic below), and am partway through the HS. Boy is this a lot easier than the -6A (though somewhat more tedious because a greater percentage of time is spent deburring). Anyway, the journey has begun.
EAA Technical Counselor #5357
Old 09-06-2009, 09:27 PM
Aerosport1's Avatar
Aerosport1 Aerosport1 is offline
Default Moving to the airport
I finally got the plane moved to the airport. All went well and had plenty of great help. Thanks to all who helped.
Bob Leffler, Brad Leffler, Jim Baldwin, Jack Ferernce, Al Moyer, Pat Ferguson,
Matt Finley and Cals towing. When I called to get prices on roll backs Cals Towing thought I was joking when I said I need to have an airplane towed.
The end is getting near
Below is a link to more photos
Geoff
http://albums.phanfare.com/isolated/...#imageID=80074
Geoff Combs
RV-10 N829GW 865hrs
1940 Piper J3 Cub
Rans S21
