Originally Posted by gmpaul
OK here the spec. on the engine
3-bladed wood/glass composite propeller for RV-9
66" diameter X 70 pitch
0-320 160HP@2700RPM
4.375 Finish Propeller Thickness
7" Diameter Prop flange
SAE-2 Pattern, 7/16' Bolts and 5/8' lugs
Thanks for the response G.P.
If you cannot get more than 2000 RPM in cruise, there is something wrong other than your prop. I would check:
1. Tachometer for accuracy
2. Ignition Timing
3. Carburetor for fuel/air leaks
How many hours on the engine since new or O/H? Has the engine recently been apart? What RPM are you getting on T/O?
Good Luck!
