Old 07-29-2009, 07:47 AM
jrouault's Avatar
jrouault jrouault is offline
Default GPS signal and metallic paint
For those of you that have mounted your GPS antenna under the cowl or under a fiberglass access panel, have you found that metallic paint on these surfaces degrades the signal?
I have two GPS antennas and a weather receiver under a fiberglass access panel on the front deck. These antennas have functioned perfectly in this location. However, my plane is now in the paint shop and I am wondering if the JetGlo metallic paint that will be used will affect performance of these antennas.
Jason
Jason Rouault
RV-7A TMX IO-360 3-Blade MT CS Prop, Flying
Fort Collins, CO
http://www.rouault.us
Old 07-29-2009, 08:21 AM
apatti apatti is offline
Hi Jason,
I recently researched this on VAF and the conclusion I seem to remember is that it is not a problem. I think the search terms I used were "GPS antenna cowl" or something like that. From what I remember, either there is not enough metal in the paint or what they are using is not really metal. I am putting my antennas under the cowl as well.
I hope this helps.
Tony
RV8A
N97AP
Warner Robins, GA
Phase I complete
Old 07-29-2009, 04:14 PM
tim rv415tp tim rv415tp is offline
Default gps signal & metalic paint
I have urathane metalic paint on my cowl, with gps ant. underneath, no problems.
Old 07-29-2009, 07:31 PM
dhammer's Avatar
dhammer dhammer is offline
Default Metalics
I don't think any of the current JetGlo products have metal metalic in them. We used to have to be careful lest a metalic stripe on a radome would attenuate the radar, but it isn't an issue any more.
Old 07-30-2009, 05:31 AM
pierre smith's Avatar
Default No problem..
...since my buddy has a silver paint on his -4. I've flown it many times and the 496 acquires satellites quickly and wx comes in with no problem either.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 07-30-2009, 11:25 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default Metallics
It is my understanding, after a discussion with a DuPont rep, that modern metallics use a polymer similar to Mylar in there flake metallics. If so, it doubt it would cause an issue with signal transparency. I have my GPS puck on the firewall, so it sees the sky through my cowl. All was perfect until I added some heat reflective sticky back aluminum stuff to the top cowl. On the next flight, my GPS was very quiet!! Felt like an idiot......
Regards,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 08-02-2009, 07:18 PM
jrouault's Avatar
Thanks for the responses. Great to hear it may not be a problem.
Jason Rouault
Fort Collins, CO
