Old 02-08-2006, 06:36 PM
jany77 jany77 is offline
Default air drill
hi guys im wanted info about air drill,is on market something good like sioux air drill but cheaper and where thanks
Old 02-08-2006, 07:14 PM
Mel's Avatar
Mel Mel is online now
I have 2 Harbor Freight air drills ($19.95 ea.) One has been with me through the building of 8 airplanes, and the other through 4. They both still run great. If they both quit tomorrow, I'm still way ahead.
Mel...DAR
Old 02-08-2006, 08:53 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
I have a Sioux (and paid for it). It's great, but nextime I'd look around. In my opinion, the only thing that really matters is that it has a good teasing trigger to control speed. I've heard good things about Dotco drills (from ATS, I think) that cost about $70 instead $200 for the Sioux.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 02-08-2006, 09:09 PM
rv9aviator rv9aviator is offline
My Dotco Mini palm drill costs $239.00 from the cheapest place I could find a year ago. I need to check ATS looks like.
One thing I learned about air drills is you don't need a high speed drill for most of what you will be using it for. When opening up rivet holes slower is better and that is 80% of what the drill is used for. For countersing and deburring the slower the better. I use my cordless on the screw driver speed for countersinking and deburring. If the cordless wasn't so heavy and combersome I would use it for everything. BTW, I love my Dotco air drill. I may buy it a valentine
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 02-08-2006, 09:26 PM
Squeak Squeak is offline
Bought a ?? Palm Size Air Drill for $99.00 from Professional Air Riveting Tools and have had no problems. Also bought a Pneumatic Squeezer and die sets. This is a great place to buy air tools with good prices.
http://www.rivettools.com/air_drills.htm
Squeak
Old 02-09-2006, 11:43 AM
compren compren is offline
Default Chicago Pneumatic
I bought a Chicago Pneumatic for $89 off of e-bay and am very happy with it. I have attached a link to the same seller I used below. It arrived in 2 days and works great.
Link
Old 02-09-2006, 03:45 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Cheap ones...
I bought a Sears one, and it was useless for fine work.
Make sure any one that you buy has a "teasing" throttle... some of the cheap ones are either ON or OFF, with a small kick back as they spin up... this makes it difficult to locate a hole precisely.
Also, since all of the power is back in the compressor, go for the lightest one you can get....
gil in Tucson
Old 02-09-2006, 04:19 PM
tsneidin tsneidin is offline
Default happy with this one:
Brand new c.p. mini reversible drill for 89.95. I have it and am happy with it, much better than the taylor I started with.
http://browntool.com/productselect.asp?ProductID=653
no affiliation whatsoever.
Old 02-09-2006, 04:35 PM
McFly's Avatar
McFly McFly is offline
Default I am happy with my CH, purchased at Home Depot
I think I paid $30 for it. You could bye three units and permantly mount a #30, #40, and a stepbit (or whatever) and still be money ahead compared to a Sioux/Dotco purchase.
I have used a friends Sioux. It was certainly a better unit but 6 times better? Hardly. Good luck.
Hugh
Old 02-09-2006, 05:54 PM
RScott RScott is offline
Get one that is small & light weight. Small in diameter is reallly helpful when you are drilling inside tight places.
You want one that will turn 2,500 rpm minimum.
If price is an issue, buy from Brown for a new one or buy off Ebay. Brown's price on a 3,600 rpm Sioux model 1412 is $185, vs. $239 at lots of other places.
Richard Scott
RV-9A Wings
