Old 06-15-2009, 06:34 PM
LarryT LarryT is offline
Default K&N Air Filter Change
Aircraft is RV-6A w/ O-320 engine and MA-4SPA 10 - 5217 carburetor.
I installed an E-3322 Air Filter instead of the E-3260 sold by Vans because I did not like the idea of taking a divet out of the air filter and patching it up with RTV.
A calculation of the perimeter of the E-3260 round filter showed that its ID is 0.2" too short in the intended oval application. A calculation of the E-3322 showed that it was 0.39" too long for a perfectly oval application. I reasoned that this might be just enough extra to stretch around the mixture enrichment casting boss on the aft side of the carb and the accelerator pump bottom cover on the pilot's side of the carb. After purchasing a E-3322 from the local speed shop, Baxter Auto Parts, I tried installing the E-3322 on the carburetor. It fit without modification.
E-3260 has a 300 cfm rating
E-3322 has a 295 CFM rating. The OD of this filter is 1/8" less than the 3260, which is what makes the packaging w/o modification possible.
For future reference, I have talked to K&N tech support and learned:
Air flow ratings are based on 6cfm/ sq. in of perimeter surface area.
Because the 3322 is a thinner ring (less pleat depth) the filter might have to be cleaned more than the the 3260.
HOwever, the filter cleaning interval for cars is 50K miles operating in a dirtier environment than our planes. 50K is 250+ hours, most of us probably don't fly that far between annuals.
Because I am a mechanical engineer I am very aware of the Law of Unintended Consequences. I hesitate to pronounce this a success since I haven't accumulated any hours in service. I guess I will just describe it as a "packaging success" that avoids cobbling up a filter.
Larry Tompkins
Old 01-24-2013, 03:31 PM
Graham Graham is offline
Default K & N Air Filter Change
Larry
I have just installed my E-3260 air filter supplied by Vans and am unimpressed by the concept of digging out part of the filter so I am keen on trying the
P No E-3322 as used by you.
Did you have to modify ANY of the mounting design to make it fit?
I would have thought thatthe lower plate would need to be enlarged as it just fits my filter.
Old 01-24-2013, 04:51 PM
Default Not a perfect fit
Graham:
You are correct. The fit is not perfect. There will be one short section of the circumference where the filter is about 50% outside the mounting plates. I deemed it a local diversion, fully supported on either side circumferentially and sealed top and bottom within the local diversion area.
I did not build my plane, so I don't know if the aluminum plates conform exactly to Van's drawings. In the interest of full disclosure, I got a PM from another VAF member who tried my idea and did not like it. I have been pleased with my results so far - so maybe I am just easy to please or in love with my own ideas :-)
Larry
Old 02-25-2014, 06:14 AM
Steve Brown Steve Brown is offline
Default It worked after some cutting. ..
I installed the E-3322, but I still had to do some cutting. Not as bad as the other filter though and I didn't need rtv to seal it.
It was a worthwhile change, but I'm going to probably remake the plate next time so I have more flexibility in shaping the filter.
I haven't noticed any degradation of performance due to the thinner filter. I read several years ago someone tried no filter and had a measurable drop in performance.
Steve Brown
N598SD - RV9A second owner
O-320, 9:1 pistons, Catto 3 blade
KRHV - Reid Hillview airport, San Jose, CA
Old 02-25-2014, 06:55 AM
Capflyer's Avatar
Capflyer Capflyer is offline
I switched my filter to the E-3322 last year. It required me to fabricate a new airbox plate attached to the bottom of the carburator but that was easy enough and while I was at it I remade the carb heat flapper in the airbox. I'm very pleased so far and happy not to worry about that big glob of RTV that was on the old shrunken filter. So far, 150 hrs and no issues.
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
