Originally Posted by SvingenB
I imagine the Ellison is alltogether a simpler install/operation than FI? Are there any differences in performance. Does anyone have any experience with both?
I have used both, the Ellison is a simple bolt on replacement for a carb. It has very few moving parts and was quite reliable for me. Ben Ellison recommends carb type heat but some guys remove it after years of no ice. I think, technically, it is a single point fuel injection system. Ellison also recommends 100LL fuel only. GM used it on some high end engines years ago like the Northstar.
I can not comment on performance issues so far as efficiency is concerned. With Ellison I pulled the mixture back to a slight rumble and then forward to get a smooth operation, worked very well. With AFP, I've done about the same to this point. The EGT's are quite spread, the injectors will need tuning down the road to get the temps more aligned. With Ellison, what you see is what you get. Also, with AFP, it will accept any kind of fuel. Both systems provide plenty to the engine.
The current AFP unit runs at 17.2 gph at full rich on take off. Ellison will do likewise.
