Old 06-04-2009, 04:16 PM
Brambo Brambo is offline
Question Rough Idle
I just went over 10 hrs in my fly-off, so decided to do my first "cross-country" today. Flew to Kingman, AZ and shut down for about 15 min (looking for a diet coke) and the hopped in to return home. I have a Lyc IO-360 and have heard all the stories about hot starts but had no trouble starting mine. It did however seem to be running very rough at or near idle. The run-up and mag check was normal (ran smooth at 1700 rpm). Although a little nervous about the takeoff, all went well and I returned home safely. Once on the ground again the engine idled normally. I assume the roughness had something to do with the engine already being warm/hot. Can anyone tell me if this is normal and what the cause might be?
Bill Rambo
RV-7A Flying
Old 06-04-2009, 04:53 PM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
Loping, rough idle is really common with fuel injected RV's when they're hot. The consensus is that the fuel is vaporizing in the injector lines. Mine does it, and there are a few threads on this forum on the subject. I have better luck if I lean aggressively during taxi and use higher than normal taxi RPM. Since I don't like to ride the brakes, this leads to somewhat faster than normal taxi.
Let us know if you figure out a surefire cure!
Guy
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 06-04-2009, 04:59 PM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
This is normal for mine, Bendix injection. It lopes and carries on a bit idling after hot starts but never misses a beat on run up or takeoff and flight. If mine is any indication then your doing fine. Maybe caused from fuel boiling off in the system (vapor lock) don?t know. I have also noted others doing the same thing as they taxi buy after starting hot.
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 06-04-2009, 07:51 PM
gear1 gear1 is offline
Default rough idle
I first experienced this when I was going through transition training in my RV8 with Dave Austin. Dave is a great instructor, hailing from Denton, TX. Right after start, the engine (IO-360-B1B) began to run rough. Dave had me start the boost pump and the problem immediately ceased! Dave explained that the higher pressure of the electric boost pump collapses the vaper lock in the injector lines. Seems reasonable to me!
Craig
PS: I would recommend Dave for RV transition. I have rudder, throttle and prop controls in the back seat, which Dave required for training in my own aircraft. What a treat to train in the aircraft that I will be flying!
CT
Old 06-04-2009, 08:17 PM
Webb's Avatar
Webb Webb is offline
Call Don at Airlfow Performance. He mentioned somthing about smaller restrictors helping this.
Webb Willmott
Jackson, MS
N32WW
Old 06-04-2009, 09:57 PM
cguarino cguarino is offline
Default What a coincidence
My RV-4 ran absolutely awful on the ground in Kingman AZ. It actually quit while I was taxing in. Maybe there is some kind of magnetic distrubance there that interfers with the gasoline atoms and ...I hope you aren't buying this. Funny though mine did run very rough there.
Charlie "T.Bear" Guarino
Springtown, TX
RV-4 Flying again with a fresh overhaul
Exempt but paid
Old 06-04-2009, 10:29 PM
nucleus nucleus is offline
Talking Yep, It Is Normal...
It has to be pretty hot for mine to do it, like 88 F. Boost pump made no difference in my case.
Hans
Dr. Hans Conser
Bozeman Chiropractor
RV-6A 195 Hours, up for sale soon?
Old 06-05-2009, 07:09 AM
smithhb's Avatar
smithhb smithhb is offline
Bill, I am at the 25hr point in my Phase 1 and I have an IO-360 as well. I also see the loping after the engine is warm and have been told by a couple of different A&P's that adjusting the idle mixture will help. The also advised that this is normal for a new-run engine and the idle mixture will help at lower fuel flow.
They also advised, as others have already mentioned, to lean somewhat at idle until you sense the engine run more smoothly.
HTH
Bret Smith
RV-9A Flying (N16BL)
Blue Ridge, GA
EAA Technical Counselor #5429
APRS Tracking
http://www.FlightInnovations.com
Old 06-05-2009, 08:08 AM
Thanks for all the replies. I'm glad to hear this is semi-normal and not some engine malfunction.
Bill Rambo
RV-7A Flying
Old 06-05-2009, 06:07 PM
osxuser's Avatar
osxuser osxuser is offline
Pretty normal and standard... Going into Chandler AZ on a 110+ degree day... I actually had those symptoms on the Carb'd O-360. Boost pump fixed it, but i threw me for a loop.
Stephen Samuelian, CFII, A&P IA, CTO
RV4 wing in Jig @ KPOC
RV7 emp built
