  #21
Old 05-30-2009, 07:51 PM
RV3 Pilot RV3 Pilot is offline
Originally Posted by ghatch View Post
Back in my Cirrus days we used a formula to calculate % Power which is directly proportional to Fuel Flow while LOP.
Formula: FF X 14.95 = HP, HP/Max HP = % Power
7.7gpm x 14.95 = 115.12HP, Assuming a 180HP IO-360, 115.12/180 = 64% Power. Sound about right?
I use that formula for an 310HP IO-550 but I believe the constant is constant for our internal combustions engines but, only while running LOP. Walter Atkins might chime in to verify.
Gerry
Might be a Misprint
Old 05-30-2009, 07:57 PM
ghatch ghatch is offline
Yes, it should be gph... sorry
Old 05-31-2009, 04:49 AM
Kevin Horton's Avatar
Kevin Horton Kevin Horton is offline
This is essentially what this old Lycoming method is doing, but it tweaks things to account for compression ratio (higher compression is more efficient, so you get more power from the same fuel flow) and rpm (less power lost to friction at low rpm, so more power from the same fuel flow). It also accounts for how far LOP you are - their data shows the efficiency dropping off if you go too far LOP. And, there is data to cover ROP too.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 08-13-2014, 12:52 PM
Noah's Avatar
Noah Noah is offline
Originally Posted by Kevin Horton View Post
I've got an old Lycoming document that describes a method to determine power during cruise performance testing, using fuel flow as the main input. It isn't usable real-time in flight, but it could be used in conjunction with flight testing to produce power setting tables for a handful of combinations of rpm, MP, altitude and fuel flow. I've played around with this power calculation method a bit, trying to figure out if it produced consistent, credible results. If it does, I'll document it in a Kitplanes article and produce a spreadsheet to use it. If it doesn't provide consistent results, then I'll drop it. I'll give an overview of this old Lycoming method in the next message in this thread.
The big question I need to answer is does this method produce a consistent power no matter what mixture is used. I will answer that question by plotting speed vs calculated power, with points at the same rpm, MP and altitude, but at several different fuel flows. I've got a bit of data from my RV-8, but it will be some time before I can get any more, and I am not completely satisfied with the stability of my fuel flow indication, which makes is difficult to draw solid conclusions from my data. Also, I really need data from more than one aircraft, with more than one pilot, to see whether this method is useable in the real world.
Kevin,
Where did this analysis end up? Ever do that Kitplanes Article?
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men? for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
Old 08-13-2014, 06:59 PM
Originally Posted by Noah View Post
Kevin,
I got enough data to satisfy myself that the method is valid. I started drafting a Kitplanes article, but never finished it. It is in the queue of a list of flight test articles I intend to write. I just need to get off TDC and crank them out. I'm hoping to take a few days off in the fall and get started.
Kevin Horton
RV-8
Moses Lake, WA, USA
Old 08-13-2014, 08:42 PM
Noah's Avatar
Looking forward to it, Kevin!
Highest Regards,
Noah F, RV-7A
Old 08-13-2014, 09:14 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Yes. You Do.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
