Go Back   VAF Forums > RV Firewall Forward Section > Fuel Injection Systems
Old 03-24-2009, 08:45 PM
Craig23's Avatar
Craig23 Craig23 is offline
Default Fittings for EI Fuel Flow Sensor?
Hello Everyone,
I am installing the red cube fuel flow sensor between my Precision Silverhawk servo body and the distribution block at the top of the engine. The FI system uses #4 hoses, and I'm wondering what kind of fittings others have used to attach those hoses to the sensor? It looks like the sensor takes -6 fittings, so do I need to get reducers? I've also read that I should use steel fittings in the fuel system, but the sensor is made out of aluminum. Any thoughts?
Craig Schwartz
RV-8 (Flying!), IO-360B1PC2 (180 hp, 1 P-Mag, 1 Slick Mag), Whirlwind 200RV, AF-3500, G496, Digiflight II, Classic Aero Sportsman Ultraleather Seats
N868RV
Santa Rosa, CA
Old 03-24-2009, 10:40 PM
David_Nelson's Avatar
David_Nelson David_Nelson is offline
Hi Craig,
I used AN816-4-4D fittings (1/4" NPT x 1/4" hose) with the "red cube". All the hoses between the AFP servo and spider were -4.
Now you've got me thinking, why don't AN nuts and fitting gall? Is it because of the coating (name escapes me at the moment).
Regards,
/\/elson
RV-7A Tip-Up
NW Austin, TX
Old 03-25-2009, 05:15 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by Craig23 View Post
......installing the red cube fuel flow sensor between my Precision Silverhawk servo body and the distribution block at the top of the engine......I've also read that I should use steel fittings in the fuel system.......
If the suggestions from EI are to be believed, it is considered acceptable to use aluminum fittings with its transducer. Review section 3.10 (page 14-15) in the EI instruction manual for both size and type of fitting required for use with its red cube:
http://www.buy-ei.com/Manuals/EI%20MVP-50P%20II.pdf
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 02-09-2016, 06:45 PM
BillL BillL is offline
I know this thread is old, but Rick is still here so - - -
Rick, I am about to mount my "red cube" exactly like your photo. Since it has now been 7 years, has it provided good service in this location/orientation?
I have the stock IO360 M1B engine.
Bill
RV-7
Lord Kelvin:
