Old 03-12-2009, 02:41 PM
24Golf's Avatar
24Golf 24Golf is offline
Default Lycoming vs ECI Engines
We will be purchasing a new XIO-320 in the next few days for the 9A and have a few engine questions:
1. Do the new factory Lycomings from Vans get run in with test prop and such as do most of the ECI buildup engines?
2. Are there any real break-in differences between the Nickel ECI cylinders and the standard Lycoming cylinders?
3. Other differences between the two to consider??
Apparently Vans has kept their engine prices the same (so far), but the ECI builds have gone up or are going up soon... This is a big purchase and we don't want to mess up!
Paul & Beth Duff
N2724G - RV9A - 1000+ Hours
Vans # 91642
FLYING 10.15.2010
BLOG: http://2flyamerica.com/
Old 03-12-2009, 03:51 PM
Chappyd Chappyd is offline
I can answer the 1st one, but not the others. My lycoming from Van's was run on a test stand at the factory, during which temps and parameters were checked and recorded. The literature says the engine is "broken in", but I still plan to follow the reccomended break in procedures. Have no idea what they put on the front for a prop.
Van's had a really good deal on engines, and the $1000 off if you buy the prop is good incentive. The warranty starts 2 years from date of delivery, or when you send the card in, whatever comes first. I think it is one year, but don't hold me to that. It's been a while since I looked.
You may get a better warranty from one of the engine builders. If I lived conveniently close to one of the better known engine shops, I might have gone that route. Nothing beats someone you can go to in person if you have a problem.
Dave Chapdelaine
N821RV
RV-7
Flying as of 7/2/11
Old 03-12-2009, 06:37 PM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default Just a suggestion
Hey Paul and Beth. If you dont have to order it in the next week or two, i would suggest waiting till sunnfun. Last years vans special was a discount off their price, FREE crating, free shipping, etc and then you also get the 1000 discount if you get the prop from them. Was a pretty good deal when crating and shipping can add up to lots after you find your price. Their oshkosh deal was similar but $500 more then sunnfun.
Hope that helps. In this economy, gotta save a buck when you can. Buys lots of fuel, or the wife a few nice nights out.
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 6 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
Old 03-13-2009, 06:10 AM
MarinePilot MarinePilot is offline
Default Lycoming Engines
Lycoming does a test run on the engine in the test cell for 1-1.5 hours with a test prop.
As far as break in, even though it is run in for that long, it would still be advisable to follow SI1427 on the initial break in flight.
Old 03-13-2009, 10:50 AM
trib trib is offline
One of the engine experts may chime in here, but I believe the initial operation performed by the builder (Lyc or ECi) is referred to as the "run-in". This is different than the break-in and is meant to be an initial check on engine assembly, not to break in the engine. The "break-in" is a substantially longer period (>25 hrs) meant to operate the engine in the optimum manner to get the rings to properly seat and result in the best efficiency for fuel/oil use.
Tim Ribble
Virginia Beach
RV-6A (only took 13 years to build )
N621TR In unrestricted operation
Old 03-13-2009, 02:14 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
I've always had good luck with Lycoming. When you order from Van's, they spec their engines so all their FWF components will fit properly.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 03-13-2009, 02:57 PM
whifof100ll whifof100ll is offline
Default Mess up?
I have a lyc and a superior engine, no ECi, but from my research, you will probably be happy either way.
Both are really fine engines.
I will tell you that my 35 year old 1500 hr LYC O320 was running great when I decided to rebuild her for calendar time reasons. Everything inside measured out like new.
Dale Lambert
RV-6 Flying, XPIO360 Catto 3bld AFS3500EE
'68' C177
Old 03-13-2009, 06:51 PM
Robert Anglin Robert Anglin is offline
Default Two pennys
OK I get in hot water with D.R. if I name, names.. And I don't write that well, but heres my two pennys. Both are fine power-plants. You well be happy with either. "E.C.I" I just put to gether an IOX-360 for my personal RV. I coulded have it any of and all the way up to brand new full data tag. I do not have a need for roller lifters on a slow turning air cooled non racing engine. We will not be going to Martenvillie with this one. I do have a need for the thrust washers between the crank and crank case. I know it will give me a good clean case boss in two to 3000 houres, if I open up the lower end then. I do have a need for the venturie intake valve seats. Engine has smother and better air flow into the combustion chamber. 4-5% or so. I will never have a need again for a plain steel or crome steel cylinder. The big boys all over the world have gone to Nickle Carbide coated cylinders. All most all the hi-end sports cars and race cars.. It wets will, you don't wear the cylinder wall now. You wear the rings. Daimler puts in in there blocks,no sleeves just coats the inside of the aluminum blocks. I have seen them go 200,000 kl. and the rings go first. We have taken new nickle cylinders and put wet cardborn in them for a few days just to see if we could get some flash rust. It dose not happen only water stains that wip off.. On an aircraft the nickle dose not care if you flew it 20 or 400 hourse last year. Keep the cam lubed from time to time along with the gear train. You will spind a lot liss down the road and last a lot longer doing it!!
Your as always R.E.A.III #80888
Old 03-14-2009, 06:31 AM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
I've been extrordinarily happy with my ECI built by Mattituck. I feel they offer some real advantages; crank thrust bearing, nickel carbide cylinders, O-rings at the case bolts, oil jet on the cam, etc.
At the time I bought my engine (Oshkosh 2007), Mattituck was not appreciably more than Van's prices on Lycomings. Since I already had a WW200RV prop and wasn't taking advantage of the $1000 off combo deal from Van's, Mattituck's ECI engine was actually a fair amount LESS expensive. One of the other deciding factors was that I get instantaneous (even on weekends) response to questions, and fantastic support through Mahlon Russel at Mattituck. Mahlon has sold enough RV engines that he really knows the details of the installation. I can't imagine getting that level of service from Lycoming.
That said, I think either choice is a good one. I would certainly wait until Sun 'n Fun or Oshkosh to buy though.
Guy
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 03-14-2009, 07:20 AM
jthocker's Avatar
jthocker jthocker is offline
Default JB Engines/ECI
At Sun n Fun 2007, 3 guys, in search of 4 engines for their RV8 projects, happened upon the JB Aircraft Engines tent. They met Jim Brod's Jr. and Sr. along with Mrs. Jim Brod Sr. Two hours later, the proverbial "Mom and Pop" engine shop had sold 4 O-360A1A ECI Titan engines.
Yesterday for the first time those engines flew in a diamond formation.
The engines, although only have about 300 cumulative hrs., have been performing flawlessly.
I highly recommend JB Aircraft Engines of Sebring Fl.
http://www.jbaircraftengines.com/
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
