In final preparation for the second, first engine start for Black Magic, I need to do my Bendix mag p lead, ground and sensor pickups. I use two toggle switches in the cockpit to ground the mags. On my old slicks, I just attached my glass panel engine monitor RPM pickups onto the external p-lead pickup. On these Bendix, I use that little washer p-lead with the screw on cap for p-lead and grounding. My question: for those of you using a flat panel, single wire, RPM pickup to your panel, how did you attach this wire using a Bendix. Did you just run the wire through the cap, through the sleeve and attach it to the p-lead washer pickup?
Looking forward to cranking this Barrett 360 up.......I need electrons
