02-01-2009, 12:32 PM
Firewall layout
Does anyone have the DWG number for the firewall layout for the RV-7A (not DWG 19).
I got a stack of plans for FF from Van's and while it has a really nice DWG for the Rv-8 included (OP-34), which tells me EXACTLY where the transducer manifold is mounted, there is nothing to so indicate on an RV-7/7A. OP-32 has a drawing showing where the AN833-6D bulkhead fitting location is (the same with OP-28 on a carbureted engine) and by it I can kind of guess where to mount it -- just by counting along the rivet line in the drawing (and I assume the hardware is the same as the RV-8 drawing), but it's odd that there isn't a specific location called out on the plans I have.
Also, it would be really cool if someone would put together an index of all the OP drawings Van's has available. Or maybe someone already has.
02-01-2009, 12:39 PM
It's been a while (and I'll look at the plans to make sure), but my recollection is just as you described. You have to kind of piece it together based on the different plans.
Bill Rambo
RV-7A Flying
02-01-2009, 12:42 PM
I guess that'll work. It looks like a matter of just counting over 3 rivets from the gusset plate and kind of fit it in line with between #3 and #4.
Makes me nervous cutting through the firewall though.
02-01-2009, 12:44 PM
OH, one other question. In looking at the instructions for the oil cooler installation, it appears that the top corner rivets on the recess are enlarged to a #12 (well, it doesn't LOOK that way, it actually says that.). I'm close to sealing up that recess and am looking on the plans (and not finding the answer) as to whether the clamps that attach there are held in place with a nut on the cabin side, or are we to put a nut plate in that location.
Which reminds me, I wish I could find my nutplate jig. If those aren't in the top 5 of handiest tools, I don't know what is.
02-01-2009, 01:24 PM
Bob
Hi Bob, what is an OP drawing ? Did Vans ever get that finders fee too you ? Gene
Gene Bumgarner RV-7 Emp./wings
02-01-2009, 04:08 PM
Unless I'm just not understanding your question...
Bob-
I think you already have the needed DWG. There is a diagram on the right hand side OP-32 that shows the exact pre-punched hole that you need to use to locate the VA-168 transducer manifold and what hardware to use. OP-28 shows the same info on the left hand side of the page.
Jim McChesney
Tucson, AZ
-7A Finishing Kit
02-01-2009, 06:05 PM
answer: nutplate. and your jig is in the last place you'll think to look. check there first.
02-01-2009, 09:41 PM
They did, Gene, and thank you very much. It was awfully good of you. OP are drawings that are for...well, I guess I don't know what it stands for OPTIONAL? Things fuel boost pump installation, or various hose runs etc.
02-01-2009, 10:41 PM
If a drawing exists but no one knows about it, is it really there?
How does one know what "OP" drawings are available? They aren't in my preview plans. I did order the FF plans so I have some of them, but I have the feeling that there are more?
I wish Vans would make more data available to builders online.... like electronic lists of drawings, searchable parts lists by models, OP drawings, that sort of thing. Oh well, nice to dream. Back to my next Aircraft Spruce order...
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
02-02-2009, 07:07 AM
VAF Moderator / Line Boy
For a list of the "OP" drawings, try going to Van's on line ordering site, and search "The List" for "OP-". I can't tell you if the results are complete or not, but it does provide a non-trivial list of OP drawings....
Here's what I got:
http://www.vansaircraft.com/cgi-bin/...&action=search
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
