Hey All,
I'm setting the brake pedals into the weldment and one item is not clear. Although I might answer my own question as I think about how to ask it.
Here is the first photo:
Should the pedal be in-line with the weldment mount?
-or-
Offset like this in the second photo:
I think that the plans are saying to drill the pedal side plate with my trusty #40 bit in about this location then once I have the pedal in the weldment final match drill with the master cylinder. This will put the pedal at an angle to the weldment.
Whatdyathink...did I answer my own question?
