Old 12-26-2008, 04:27 PM
datsclark datsclark is offline
Default rib-spar seperation during rivet
After a few months hiatus from the project, I got back at it today. I riveted the front spar/rib together in the vertical stabilizer, but even with the best pressure and clamping i could do, the ends of the ribs came up a little bit. I'm not really happy with this result:
It looks a little worse than it is in this picture. The space is about half what you see, its just reflecting the height of the gap (top half is mirrored).
Should I drill out and try something else?
RV7A/TU Finishing Kit
Old 12-26-2008, 07:10 PM
ignacio ignacio is offline
DONT WORRY MANY HAVE DONE THE SAME. I CHOSE TO JUST LEAVE THE FEW I DID ALONE ON MY FIRST WING. DID YOU TRY USING A SMALL PIECE OF RUBBER HOSE OR O-RING TO SQUEEZE THE RIVET, THAT SHOULD HOLD DOWN THE RIB DOWN NICE AND TIGHT. IVE LEARNED AND SO HAVE OTHERS THAT TRYING TO FIX A PROBLEM LEADS TO WAY MORE.
Old 12-27-2008, 11:56 AM
JonJay's Avatar
JonJay JonJay is offline
Default Are the rivets fully formed?
It is hard to tell from the pic but it does not look like the rivets are squeezed enough. That might help. Otherwise, as long as the rivet has not swelled between the ribs, leave it and move on.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 12-27-2008, 12:10 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Use clear hose
I like to use clear hose, you can pickup at Home Depot. Cut off a 1/4" section, buy a diameter that is no larger than your squeezer set. I like the clear because I can still see the rivet. I does work great to keep the parts tight together while squeezing.
Cheers
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 12-27-2008, 12:46 PM
rvbuilder2002's Avatar
Andrew,
Do not drill out these rivets. You will almost certainly make things worse.
The other reason not to is there is nothing wrong.
It is quite normal for some material distortion to occur in this thin of material when setting 1/8" rivets with this close of edge distance. It happens because of the distress caused by the rivet head forming against the thin material. You can reduce it by always (when possible) putting the manufactured head of the rivet against the thinner material. Sometimes there is thinner material on both ends of the rivet (such as a rib on both sides of a spar) and then you have no choice.
Scott McDaniels
Hubbard, Oregon
Old 12-27-2008, 12:58 PM
Finley Atherton Finley Atherton is offline
Andrew,
This is similar to the problem you will have when you rivet the rib tabs. See http://www.vansairforce.com/communit...ead.php?t=6486 for suggestions.
Fin
9A
Old 12-28-2008, 12:59 AM
Pirkka Pirkka is offline
Another thread about similar problem and solving it.
http://www.vansairforce.com/communit...ad.php?t=13322
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
Old 12-28-2008, 07:51 AM
airguy's Avatar
airguy airguy is offline
Agreed. You'll most likely make it worse trying to improve the situation. Having the shop head on the correct (thin material) side helps some with this, but there are some locations where the contortions required to be able to buck it that way are just too much...
Old 12-29-2008, 10:00 AM
Thanks everyone for the help. I decided to take the general consensus here and just leave it alone. I knew about having the manufactured head on the thinner material (where possible), but I wasn't really thinking that through. It seems it would also be a good idea to always put the manufactured head on the side that would bend down easier, which is exactly what i did not do.
Live and learn, thanks everyone! I finished the vertical stabilizer on Sunday, now on to finishing the rudder!
