Old 12-03-2008, 05:54 PM
sglynn's Avatar
sglynn sglynn is offline
Default heat to remove a dent???
What do you think about using heat from a small torch, not just a heat gun, to remove a little dent, or wrinkle out of the aluminum skin? I have a small dent that I did hammer out carefully until almost flat, but you can still see the aluminum is not perfectly the way it was. I've read about heat shrinking skins. Can I use a little propane torch and get the aluminum to shrink back into perfect shape? I'm inclined to "get over it" and move on. But a car guy told me that heat and a little tapping should make it perfect again.
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
Old 12-03-2008, 05:58 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
It could also burn through, or actually make a larger dimple. I'd move on, as these dents are easy to fill and paint over. But, you can always practice on scrap.
L.Adamson -- RV6A
Old 12-03-2008, 06:43 PM
cytoxin's Avatar
cytoxin cytoxin is offline
dont do it. you will certainly change the heat treat of the material. move on and rethink it in 6 months. i promise it wont seem like much of a concern then. IMHO i would say it would be a mistake to try it. YMMV
William Weesner/ still kicking.
Old 12-03-2008, 07:16 PM
rvbuilder2002's Avatar
L.Adamson -- RV6A
I agree with the advice so far... and by the way, heat wont shrink the skin, it makes it expand (just like any other metal).
Also, hammering on a dent or wrinkle is not the nest way to remove it. It can caused localized thinning and stretching which makes the skin fit even worse. Not that it shouldn't ever be done, but it must only be done in very specific situations and even then be done very carefully.
Scott McDaniels
Hubbard, Oregon
Old 12-03-2008, 07:40 PM
RatMan RatMan is offline
I've never heard of using heat to get rid of a dent but I have used ice to get rid of dimples left by hail. Takes a hot day, a little ice and a bit of time but it works. Park in the sun and let the skin heat up ten hold the ice in the middle of the dimple, repeat as needed or until your hand is cold enough that you decide you can live with the dent. Dry ice works better but a lot more caution is needed.
You didn't say where the dent was. Mine was on the hood and roof of pick-up trucks.
John Ratliff
N898R
RV-8
Saucier MS
Old 12-03-2008, 08:11 PM
szicree szicree is offline
Thumbs down
Please don't take this the wrong way, but I would advise you to be very suspect of advice from "car guys", "boat guys", and even "airplane guys". If I had a buck for every time I took somebody's lame advice and had it go completely pear shaped on me, I'd be flying one of them John Travolta planes by now. Walk into any Home Depot and ask a technical question of the first kid that walks up. It's very important that you give the impression that you know absolutely nothing. This'll really embolden the guy to let the b.s. fly. All you're getting is an inaccurate recitation of all the lame advice that he's heard over the years and NO first hand knowledge.
A few weeks ago I got to listen to a self-proclaimed car expert explain to me how a completely worn out auto paint job could be made like-new by simply shooting it with a couple coats of clear. No prep, no scuff, no nothing. Said he's heard of lots of guys doing it. Never mind that the old paint had huge areas of old clearcoat flaking off and that the exposed color was chalky. The new clear will magically fix it all! Ridiculous.
There are guys (and gals) on this forum whose knowledge and level of craftsmanship is downright amazing and you can sometimes spot them doing crazy things like carving their own props. Find out who they are and take their advice. Regarding your dent, I say move on and fill it before paint. It'll be such a tiny part of the ridiculously laborious paint process you'll actually barely notice.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 12-03-2008, 08:38 PM
Cougar68 Cougar68 is offline
I'm a "car guy" (proud of it too) and know exactly where his advice is coming from. On older cars the body panels will stretch and oil can. One of the ways to fix it is to use a propane torch to heat a small spot up and then set ice on the spot to cool it quickly. The metal will shrink slightly and if you did it right the oil can will be gone. Works great for an old car roof.
There's no way I'd do it on an airplane though. For the most part car skin isn't structural and screwing with the metallurgical properties isn't going to come back to bite you.
Old 12-04-2008, 07:39 AM
cytoxin's Avatar
all you will likely end up doing is causing it to oil can. Hammering thins the metal and this cause it to expand, leading to an oil can condition. then you have to use a serrated faced hamer to shrink it and theres no way that can be good for a stressed skin. let it ride and fill it later. as undulated as these things are it highly unlikley anyone will ever notice.
Old 12-04-2008, 09:13 AM
videobobk's Avatar
videobobk videobobk is offline
I agree on NEVER heating aircraft aluminum and that hammering is iffy at best. Since you have already hammered this area, it probably won't work, but the "paintless dent removal" method will work on AL without side effects. I'm not good at it, but I did use it on several dents and it works! My Lab put five toenail marks in my rudder just before I was going to close the trailing edge. Took 'em out perfectly! Search on it if you want to try it. Practice on scrap and you won't screw anything up. Pretty easy, really.
Bob Kelly
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 12-04-2008, 09:39 AM
Christopher Murphy Christopher Murphy is offline
Default heating AL skin or hammering
Sorry to say this but you have already messed up by hammering the dent out.
Heating the metal is taboo. It anneals the material and causes it to loose its physical properties and hammering out the dent work hardens the material making it brittle. You should have a copy of AC 43 if you built your airplane and if you don't have one, get it and read it. Airplanes and their repair and maintenance is not a matter to take lightly. It is not the same as working on your car.
C. Murphy former sheet metal mech for a major airline.
