  #21
Old 11-17-2008, 07:15 PM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
Originally Posted by Bill Dicus View Post
Don't mean to hijack thread, but has anyone come up with a good strong cargo net to attach to these and contain baggage? Bill
I like motorcycle style bungi nets like these: http://www.aerostich.com/product.php...cat=283&page=1
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 11-17-2008, 07:30 PM
Deems Davis Deems Davis is offline
Default Yup [LP4-3'S
Originally Posted by trib View Post
Deems,
I was looking for something to do with my leftover hinge. Were these just pop riveted to the floor or mounted otherwise?
Yup LP4-3's , (used the underlying rib's in the baggage areas for added strength where possible.)
Deems Davis
RV10 N519PJ
http://deemsrv10.com/index.html
Old 11-17-2008, 08:57 PM
Bill Dicus Bill Dicus is offline
Thanks Guy. Will check these out. Bill
Bill Dicus
Shorewood (Milwaukee) Wisconsin
RV-8 N9669D Flying 12/4/14!
Flying Pitts S-2A, Piper Lance
Old 01-21-2010, 12:41 PM
Snowflake's Avatar
Just to freshen the thread a bit, as i'm searching for tiedown ring options right now... Here's an updated link to the tiedowns on the PitPosse site. As of this posting, they are $9.95, vs. $15 from Vans, and $41 from Aircraft $pruce. To be fair, AS does include rivnuts, but still...
http://pitposse.com/quditian.html
Rob Prior
Old 01-21-2010, 12:56 PM
Super Moderator
I just put 4 of these in the baggage compartment of my new RV-10. I also installed extra nutplates (10-32) right up under the rear seat outboard corners, so that we can remove the rear seat, move the tiedowns, and put the bicycles in there or other large luggage when we don't need all four seats.
Vic
Vic Syracuse
www.Baselegaviation.com
Old 01-21-2010, 02:23 PM
drill_and_buck's Avatar
drill_and_buck drill_and_buck is offline
Default Budget Tiedowns
A trip to the local big box store will allow you to install these budget tie downs for under 50 cents each.
Budget Tiedowns
Mike Draper
RV-8 N468RV
First Flight 11/13/2011
TMX0360, Pmags, CS
Bridgewater, MA
KPYM
Old 01-21-2010, 03:16 PM
prkaye prkaye is offline
Following a local builder, I used two motorcycle cargo nets ziptie together. For tiedown rings to hook the nets to, I used inexpensive hardware from a local marine supply store.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 01-21-2010, 03:20 PM
flyboy1963's Avatar
Unhappy not really tie downs.......but
the brilliant John Horton ( my builder) I guess came up with a baggage tie inspired by the seat tracks in a Convair or something he was gutting?
Running across the floor behind the seats, and at the rear of the baggage compartment.......
a piece of 3/4" angle with holes/slots drilled in it's entire length gives almost infinite tie locations. It weighs only a few ounces, stiffens the floor, and keeps stuff from sliding forward into the flap tube. (sorry I'm no good at pics.) kinda like this
____________________________________
(__) (__) (__) (__) (__) (__) (__)
remember, your 100 lbs of baggage becomes 2000+ lbs. in a good crash decelleration.....and you don't want to be 'rear-ended' or decapitated by that VW beetle behind you ! I admit, to keep all my **** under control, I usually just use a cargo net from Princess Auto that's for quad's...probably only good for a couple G's!!!
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 01-21-2010, 04:10 PM
mannanj's Avatar
mannanj mannanj is offline
Default Tiedowns
Pit Posse has an E-bay store. You might be able to get them at a price lower than $9.95.
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 01-21-2010, 04:56 PM
Jim P's Avatar
Jim P Jim P is offline
I've found you can use something like this with a single ear. I've used four of these, two aft, two forward and use bungees to secure loads with great success. My floors are screwed in so moving these around or adding more is really easy. These are probably available in the aviation aisle at Lowe's for probably a buck and a half.
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
