11-12-2008, 11:55 AM
Baggage Tie downs
After looking at Vans quick disconnect baggage tie downs and getting sticker shock ($25.00 each), I did a net search and found a supplier that has similar tiedowns for $7.95 each.
I just got them in and they look great. They come anodized in multiple colors and I am sure your baggage floor will rip up before they break. Here is the website if anyone is interested.
http://pitposse.stores.yahoo.net/noname75.html
Jim Kinsey
7A Finishing and Engine
AFS screens
IO360A1A, Catto 3 blade
N527K reserved
Donated thru 2018
11-12-2008, 12:18 PM
Thanks!
Just what I was looking for!
Jim Buechler
RV 9A - N194HW
I/O 360, Whirlwind 200RV C/S, Slider
RV 10 - 313RT
Beechrv9a@hotmail.com
11-12-2008, 01:48 PM
interesting Jim...
What mount location will you be using?
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
11-12-2008, 02:15 PM
Kent
Not positive yet. I am thinking of using rivnuts like Van supplies for his and get them as close to a rib or bulkhead as possible. May need to use a doubler plate due to the thin floor and side panel thickness.
Jim Kinsey
AFS screens
N527K reserved
Donated thru 2018
11-12-2008, 02:56 PM
just one approach
I mounted one in the center at the rear on the cover plate that goes over the elevator rod channel, puts it between the two support ribs and is easy to install. I put 2 others on the vertical members by the side of the seat backs, again easy to install and hidden by the seats.
11-12-2008, 03:17 PM
great find!
Jim,
Nice find! Did you notice the track kits they carry? Two four foot tracks and four tie down rings for $65 bucks. good deal in my book. I'm thinking of mounting a couple of tracks on the floor and maybe even the walls of the baggage area.
I just noticed they are located just a few miles from my office! I think I'm going to go check them out in person.
Bruce Smith
Clearwater, FL
RV-7A Fuse
N27DB reserved
web.tampabay.rr.com/flrv7a
"Political correctness is tyranny with manners."
Charlton Heston
11-12-2008, 04:01 PM
Here's another option (cost less)
Credit for this needs to go to David McNeil who showed me the tip. Simple piece of piano hinge, cut, drilled and rivet4ed to baggage area, Folds nearly flush and can be hidden under carpet when not in use:
http://deemsrv10.com/album/Sec%20The.../DSC06655.html
Click forward for 4-5 additional pics installed.
11-12-2008, 05:56 PM
Senior Curmudgeon
Deems, what is the upholstered interior panel shown in the shots??
I know that Classic Aero is working on an interior for the ten------are you the Guinea Pig on this????
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
11-12-2008, 06:49 PM
Jim,
I bought a handful of those three weeks ago to use in my baggage compartment.
It is best if you plan to install these with #10 plate nuts while building but if you didn't install them while building, here is what I'm in the process of doing:
Use #10 keyed riv-nuts. Keyed riv-nuts have a small bump on the underside of the top ring. When set, this key helps keep them from spinning. (I bought and tried both, and the non-keyed riv-nuts spin in the hole much easier than the keyed ones but even the keyed riv-nuts will spin.)
The other trick I did was to drill a dimple in the bottom of each base but not all the way through, centered between the two holes. The idea is that by putting the dimple over an existing rivet in the baggage compartment, you can use the two holes in the base as your drill guide.
Once the 1/4" holes are drilled, it is a simple matter to install the riv-nuts and screw the bases down.
I would also recommend installing the riv-nuts through both the floor and rib flange for extra strength.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
11-12-2008, 06:51 PM
Originally Posted by wingtime
Jim,
Bruce,
Way back when I bought a set of the tracks to install in my -9 and never used them because of the weight. The SbS baggage compartment is small enough you can get away with just for tie-downs.
BTW, these things are designed for securing motorcycles and they are beefy.
Bill R.
SC86 - Easley, SC
