  #21
Old 03-14-2007, 07:13 AM
AlexPeterson's Avatar
Originally Posted by Ironflight
Question Alex....straight back filter, or angle adapter (sticking up at a 45 degree to the side, "mouth" down)? Just want to make sure we're not talking apples and oranges...
Paul
Straight back, tricycle gear.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 03-14-2007, 07:51 AM
sf3543 sf3543 is offline
I have the same set up as Paul. The 45 degree adaptor, with a spacer, on a TD RV8.
The last time I changed oil, I did the following and the oil did drain out of the filter.
With a still warm engine, I punched a hole in the top rear of the oil filter. While draining the oil, I lifted the tail and left it in the up position for about an hour. Then put the tail back on the ground and let everything drain over night. The next day, I took off the filter, expecting a bunch of oil, but it was almost dry.
I was getting oil from the filter in previous oil changes, but I didn't use this sequence, so I don't know if this is a fluke, or not. At any rate, at least the filter is easy to get at.
Steve Formhals
A&P, Tech Counselor & Flight Advisor
RV3B
RV8
Old 03-14-2007, 08:25 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I had this exact same experience on one oil change, a few chanegs back Steve...it gave me hope that I was coming up with a clean system....Alas, when I repeated it the next time, the silly filter dumped all over again....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-03-2008, 03:51 PM
Rolly9 Rolly9 is offline
Default Changin' the Oil
What's the trick to changing the oil w/out getting it all over everything?
Rolly Clark
Rolly Clark
RV-9
Eatonton, Ga
Old 11-03-2008, 03:52 PM
Geico266's Avatar
Geico266 Geico266 is offline
Rolly Clark
Rotate the plane 180 degrees. If that is alot of work or your hanger is not tall enough you can loosen the oil filter, place a plastic bag over it and take it off the rest of the way. Works for me, just take your time.
Draining oil out of the sump is easy. Just make a gutter out of something and wire it in place.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 11-03-2008, 05:05 PM
N941WR's Avatar
N941WR N941WR is offline
Rolly,
Changing the oil is easy, you just gotta have the right helper.
The trick is to get the filter off. I do the same thing Larry does, use a bag, not tip the plane up on its nose.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-03-2008, 05:09 PM
Chino Tom's Avatar
Chino Tom Chino Tom is offline
Ditto on the plastic bags. I use the the grocery store kind. Slide one handle over the filter after you have loosened it. I have about 5 years of oil change bags stored before they outlaw them here in the peoples republic of CA.
Tom Prokop
Chino, CA
RV-8A,180/CS/Carb, AFS 4500 EFIS/EMS
RV-6, sold, 820 hrs of fun.
Old 11-03-2008, 05:16 PM
N55CU N55CU is offline
Default Oil Change Mess
Only relief on oil filter droppage is to drain it cold with no oil in the filter. But then the oil analysis people tell you that you have a high fuel content in the oil because you must not have warmed the oil properly! Smart guy's the analysis people! To save the mess when I remove the oil screen is to cut a water bottle at an angle and place it beneath the screen when I back it out and that catches about a whole bottle worth of oil.
Randy Utsey
RV-7
N55CU
Charlotte, N.C.
Old 11-03-2008, 05:59 PM
rwhittier rwhittier is offline
Rolly Clark
A long time ago with a 0-360-A4K I used to make a heck of a mess when changing oil filters. That darn horizontal filter mount was impossible get drained enough to not make a mess.
Then I found a kit that worked pretty good. It was a punch, a hose and a large hose clamp. The clamp had a nipple with an O Ring installed in it. Punch the hole in the top of the filter, put the clamp around it and put the nipple into the small hole you just punched into it. Install the drain hose and rotate the filter half way so the hole is on the bottom side. Then go home and let the oil drain from the filter. What little oil was left was easy to contain with a shop rag.
ACS sells a better version than the one I described here
Roger Whittier
RV7A Quick Build, Tip Up
N1MY Reserved - Canopy finished - Wings mated, Engine hung, electrical 95%
Old 11-03-2008, 06:00 PM
Joe Hine Joe Hine is offline
To prevent the mess from the oil filter, I made a "V" shaped piece of aluminum scrap, long enough to go from the bottom of the filter to the side of the aircraft, I loosen the filter just enough for the oil to start leaking out. It hits the aluminum and is directed to the side where it drips into a bucket. Don't get a drop on the firewall. There is even a handy hose under the filter to rest it on so I don't have to hold it.
The channel is about two inches wide, and bent into a gentle "V". I think I got the idea in this site a couple of years ago
Cheers.
Joe Hine
RV4 C-FYTQ
Fredericton NB
Canada
