Old 07-12-2008, 07:47 AM
prkaye prkaye is offline
Thanks Paul. For anybody who has installed the smaller vents, do similar comments apply?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 07-12-2008, 09:18 AM
Sparky's Avatar
Sparky Sparky is offline
Phil, The same would apply with the smaller vents. The hole in the mounting plate or panel for the vent would of course just be smaller.
Paul Winkels
RV7 Standard Build - First flight 4/16/2016 - Now Flying!
Old 10-21-2008, 06:21 PM
hydroguy2's Avatar
WOW got my Steinair large vents yesterday and as everyone has said they are excellent!
I'm a budget shopper and it was tough spending $$'s on vents, BUT These vents are in a different league from the factory ones.
of course I couldn't just order vents(its a waste of shipping cost) so got a couple other trinkets.
Kudo's to Stein
Old 10-21-2008, 10:48 PM
yakdriver yakdriver is offline
Not only do they give you plenty of ventilation but they seal tight on those cold days. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 10-22-2008, 05:48 AM
ChrisL ChrisL is offline
Installed mine a few weeks ago - the $200 is very much worth it as the quality is 10 fold when compared to the Van's vents.
Chris
Chris Lund
Portsmouth, NH
RV-7 Emp, Wings, & Fuse Done - Working on the Canopy
Old 10-22-2008, 06:56 AM
the_other_dougreeves the_other_dougreeves is offline
Originally Posted by Tony Spicer View Post
Strongly disagree with that observation. I have the 1 1/4 vent in my -3, and if I wore a toupee that small vent could surely blow it off.
Yeah, but if you fly a -3, who's going to notice?
Yet another reason for the -3!
TODR
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
Old 10-28-2008, 09:47 AM
Default AffordablePanels vents
Are the Stein vents the same as the ones from AffordablePanels ?
Phil
RV9A (SB)
Ottawa, Canada
Old 10-28-2008, 10:00 AM
SteinAir SteinAir is offline
No-No-No! Not even in the same league. Granted theirs are a step up from Van's, but the difference between the Van's Plastic Vents and the aformentioned vents is just about the same technological step between those and the ones we sell! HUGE difference in the construction and operation of them all around.
The only thing similar between the two is that both of ours are aluminum instead of the plastic from Van's. Quick dissasembly of both types will show you huge and obvious differences.
Stein
Old 10-28-2008, 10:07 AM
Thanks Stein. Here's the reason I asked... I'm seriously considering the AffordablePanels XL panel (for RV-7,9 slider). This has pre-drilled cutouts for the vents, that are drilled to match either Vans vents, or their own aluminum ones. I presume these cutouts will not work directly with your vents?
Phil
RV9A (SB)
Ottawa, Canada
Old 10-28-2008, 10:25 AM
rocketbob's Avatar
Just want to make a comment about the aluminum vents with the white dot. A friend of mine who owns a 6A makes these vents, and they are of EXCELLENT quality and are used on a few new aircraft, such as the Quest Kodiak and others I can't remember at the moment, and are sold thru AC$ and Wicks. He sells several dozen each month, and they are a direct replacement for Van's plastic vents. Unlike the other vents, they seal tightly when closed. The white dots were put in because folks were over-tightening them when closing, so pushing on the white dot is an easy way to make them idiot proof. I have them in my RV and have never had to push on the white dot to open them back up, all it takes is a light touch to close them.
I'll also add that they're made in the USA on a machining center in the back of a garage, if that sort of thing appeals to you.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
