Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 10-26-2008, 06:04 PM
Kevin Horton's Avatar
Kevin Horton Kevin Horton is offline
Default MT Prop Blade Colour for Night Ops?
I will be buying a new MT prop, and need to decide on the colour for the blades. I like the look of the gloss white blades, but wonder if there is any issue with reflections of the strobe lights off the back of the blades in night or IFR ops. I've got strobe lights in each wing tip, and one on the rudder bottom.
Comments?
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 10-26-2008, 06:19 PM
N55CU N55CU is offline
Default MT Prop Color
Hi Kevin, I believe that MT paints the back of the prop in black only to avoid any glare. My MT prop is yellow on the front and the back is black
Randy Utsey
N55CU
RV-7
Old 10-26-2008, 06:32 PM
Mel's Avatar
Mel Mel is online now
Default Just to be "nit-picky"!
The technical term for the "back side" of the prop you guys talk about is the "face" of the prop.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-26-2008, 08:28 PM
mburch's Avatar
mburch mburch is offline
Ditto what Randy said. The MT I had on my last airplane was flat black on the back side... er, the side that you can see from the cockpit...
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
