Answer to the mystery P Mag problem
I finally have the Mags back from Emagair and the solution to all my problems with the P-Mag was finally discovered.
This message was sent to me by Brad and I believe it was the problem all along.
"The shaft was pushed in on 1019, (yellow LED alert) may have happened during the return shipping. If it was that way when you had it, you would have seen the same thing (Yellow LED) and it would not work at all. When position was corrected, it worked fine on the bench. We went ahead and replaced the circuit board anyway to make certain there wasn?t something else on causing a problem. We did the service bulletin on both so they are current."
I never even realized that you could get a yellow light on the LED indicator. I checked it after I installed it and timed the mag. It looked sort of green to me, how green, yellow is a combination of green and red. It certainly wasn't red so I thought it was green.
Oh well, My loss is your gain.
The Mags are back and are now for sale. I have over $2,300 in costs for the mags, auto harness, plug adapters drive gear, plugs and maybe $400 in shipping costs. Expensive lesson but time to move on.
Brad suggested that a fair price might be to knock 20% off the total.
What do you think? Any offers?
Mike Ice
