10-10-2008, 02:36 PM
What else do I need?
Originally Posted by Brantel
Brian,
I am not a EE but do like the idea of doing my own LED position lights. I am up for ordering these to help get the 20 needed but what else will I need? How complicated is this, I have no experience with a soder iron but could find local help. If you could post or PM the other items and some instrucitons, I assume you will be installing in the cutout wing like I have. Thanks, let me know and I will place the order.
Cheers
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
10-10-2008, 03:08 PM
Just ordered 2
Brian,
Thanks for running with this, and I'm glad I've been procrastinating regarding giving up on the roll your own led project.
I just hit the Matronics AeroElectric web site and ordered 2 assemblies.
Dave Cordner
RV7 - N898DC (rsvd)
Fuse, Finish, FWF
Arvada, CO
10-10-2008, 04:00 PM
Mike,
I will gather together the links to the threads that detail what I have a little later tonight. Tons of info here in the archives detailing these roll your own versions.
The short version:
If you want to copy the most common design, you will need two drivers from Bob, 6 cyan K2 star LED's, 6 red K2 star LED's, some mirrored plexi and something to make a heat sink out of.
Originally Posted by RVG8tor
Brian,
Cheers
10-10-2008, 05:07 PM
Count Me In
Im game
what is the cost for the filters
Thx
______
TGudz
EP, TX
RV7
Wire/Elec Phase
10-10-2008, 05:14 PM
bought 2
Just ordered two. I have the rest of the material sitting around waiting on me to start the wings
_____________
Xavier
RV-7 build in progress
www.theaviatorx.com
" Genius is persistence in disguise"
10-10-2008, 05:23 PM
me too
Just ordered two...I really don't think it will be long for bob to get 20 orders. I've built two sets of nav lights and used a cpu heatsink...(not my idea...picked it up here)...purchased on ebay for about 3 dollars. I can send you a pic if you like..
On to the next project....
Thanks Brian for staying the course...
Carl Bridges
RV7 N278RV
NOW FLYING
10-10-2008, 05:57 PM
Brian,
Thanks I look forward to the links. I went ahead and place my order. The timing is perfect I just this week decided to get off the fence and get stared on the lighting in my wings. I have been putting it off since I did not know which way I was going to go.
Cheers
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
10-11-2008, 10:21 AM
Brian,
Thanks for getting this done. I just ordered two filter board assemblies. I've already got the BuckPucks.
Paul Winkels
RV7 Standard Build - First flight 4/16/2016 - Now Flying!
10-11-2008, 07:26 PM
Here is just one of many links:
http://www.vansairforce.com/communit...ght=data+point
Read it all because some things changed from start to finish...
Some things I have learned:
1. The LEDDynamics driver will trash your radio's with noise. Bob's filter seems to nip this in the bud.
2. Order cyan led's instead of green.
3. K2 stars do not have to be isolated from each other, most others do.
4. Use thermal epoxy to mount the LED's instead of screws, much easier and works just as good.
5. LEDSupply.com is a great source for LED's and drivers.
6. When you run multiple series runs of LED's in parallel on the same constant current driver, you need each series run to have at least three LED's. This allows the LED's to properly share the current from the driver.
7. Socket A cpu heatsinks from old computers make great heatsinks for these lights.
8. Use artic silver thermal paste between your heatsink and base plate.
9. 6ea K2 stars on each side running at 500mA will make you see spots!
Brian,
Cheers
