Old 09-17-2008, 09:34 PM
vonjet vonjet is offline
Default Push Button Starter
Anybody used one of these cool push button starters in their airplane? I am using a push button start and Id like to find something unique. Anybody know if these will work in Aircraft?
http://www.sfxperformance.com/parts/IGN2001B.htm
Old 09-17-2008, 09:51 PM
Mike Ice Mike Ice is offline
Default starter button
Vonjet,
I can't imagine why one of those buttons wouldn't work and they look pretty cool. Go for it. It is your plane.
Mike Ice
Old 09-18-2008, 04:35 AM
JohnJacobsen's Avatar
JohnJacobsen JohnJacobsen is offline
How big are they? Couldnt find any specs.
John Jacobsen
RV7 Flying "Aluminum Falcon"
Zenith CH750 (Scratch building) SOLD
Locost 7 (Lotus 7 replica)
Taylor TX
Youtube channel: http://www.youtube.com/user/johnjaco...e=results_main
Old 09-18-2008, 05:29 AM
Geico266's Avatar
Geico266 Geico266 is offline
I have flown planes with push buttons and from a safety stand point they are not a good idea. There is no key to lock the aircraft's ignition. Anyone can get it the plane turn on the master and push the button.
Story Time: I am reminded of SnF a few years ago where a customer was sitting in a light sport display plane and said; "What does this button do"? The Rotax 912S engine started full throttle, plane shot across a busy area, hit a ditch, went airborne, and then crashed into 3 cars. Push button stater? NOT a good idea in an airplane.
Go with the key lock. When the key is on dash or in your pocket the plane cannot be started.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 09-18-2008, 05:53 AM
Mark Castle-Smith's Avatar
Mark Castle-Smith Mark Castle-Smith is offline
The specs from the manufacturers web site are as follows:
Switch Acutation Style: Push Button
Circuit Activation: Momentary
Amp Rating: 10A
Volt Rating: 12V
Terminal Type: Screw
Material: Plastic
Quantity: Sold Individually
Mounting Size: 24mm or 31/32"
Note that the he amp rating on the specifications does not say whether this is a rating for a resistive or inductive load
On face value this switch should be fine, especially if it has been design to control a car's starter contactor. However I would call the seller to clarify (don't mention it is for an aircraft!) as a contactor is a highly inductive device that is very hard on its controlling switch (don't forget to install the spike controlling diode).
However I do agree that installing a push button switch without protection is probably not a good idea in an aircraft, but if you want the look of this switch you could always protect the starter circuit with a hidden switch or using a simple SPST key switch in the circuit.
Mark
Old 09-18-2008, 07:08 AM
Mel's Avatar
Mel Mel is online now
Default Don't count on it!
I have seen MANY aircraft ignition switches that were worn enough that the key would come out with the switch in the "left" position. I had a friend whose Swift started with a small turn of the prop. The airplane had been sitting for days and the mixture was at ICO.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-18-2008, 07:36 AM
bsacks05's Avatar
bsacks05 bsacks05 is offline
I love my push to start button from B&C. I also keep a throttle lock on when I'm not in the plane. Come to think of it though, wouldn't a mixture lock be better?
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
Old 09-18-2008, 08:02 AM
mannanj's Avatar
mannanj mannanj is offline
Default Push Button
According to the item description, it requires a key to illuminate, and I suppose arm the starter button.
Go for it!
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 09-18-2008, 08:09 AM
Sam Buchanan's Avatar
been here awhile
I too am a fan of the push-to-start switch. I have had to dig the ignition switch key out of my pocket after getting buckled up...........zero times!
Never worried about unauthorized or accidental use of the plane. Hardly anyone can figure out how to get past the tip up canopy latch.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 09-18-2008, 08:29 AM
N520TX's Avatar
N520TX N520TX is offline
Default S-2000
My Honda S-2000 has a starter button - when I test drove it yrs back I thought it was the coolest thing. When I started work on my 7a back in 2003, I just knew it had to have one as well. I managed to locate a genuine honda starter button (http://www.handa-accessories.com/s2000-03.html near the bottom of the page) and sure enough, it's in my 7a. It's not rated to carry the starter current itself, so a relay was required.
Ron Walker - 40XS
RV7a - Flying
RV10 - Flying !
FFI Flight Lead - www.FalconFlight.aero
