Old 08-12-2008, 05:38 PM
Bart Bart is offline
Default Rivet Head Door Pins Install Question
Has anyone installed the rivet-head aero after market door pins? My question is how the long door-tube gets modified for the pin. I did not get instructions and it appears that you need to cut the diagonal cut on the end and tap it for the new pin. The length seems about right if I did that way but before I cut I wanted to see what other folks have done.
Old 08-12-2008, 06:28 PM
PJSeipel PJSeipel is offline
You'll have to get the pins short enough that when they're in the retracted position the door shuts without them hitting on the blocks. It'll probably be a little shorter than just the diagonal.
PJ Seipel
RV-10 #40032
Old 08-12-2008, 06:50 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
I just did mine and you'll have to cut and try a few times to get them right. Start your first cut at the start of the angle. Be sure your linear gears are installed properly so you get full travel. Keep trimming the pushrods until they are just flush with the plastic blocks (retracted position).
I had to mill my aluminum pin blocks a bit as there was a bit of variation in recess depths fore and aft on my doors for the plastic guide blocks.
You'll have to modify the door seal setup to clear the aluminum blocks.
I feel a lot better about this setup over the Vans one but also added the safety latches to the main handles. I posted some photos last week on this easy mod.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
