Hi again.
Thanks for all the inputs folks!
I'm finally back home after 5 days at work, so it's time to focus on the RV again.
Here's some answers to the questions:
I don't know which upgrade I got when I sent P-mags to Brad in April this year, but at least by that time, they got the latest upgrade. Does anyone know if there is a newer upgrade out?
I've only flown one trip (lasted 2 hrs) so far, and I've not yet swopped P-mags or anything else because I wanted to talk to Brad first.
Tomorrow I'll verify plug routing, wiring and timing.
I'll also check if it's possible for the P-mag to move when it's heated up.
I'm running the autoplugs and wires which the P-mags came with.
Below is two pics taken during the first flight.
The first one is take after 36 minutes and the second after 73 minutes.
You'll see that there's no RPM-indication.
The indication quit showing above approx 2000 RPM during takeoff and showed up again during taxi in.
I had just installed the "RPM-board" from AFS, so I was thinking everything was ok.
I had however, brought along a digital RPM-counter and had taped it on top of the glareshield. So that's what I used during the flight.
The oilpress was at 50-52 for the entire flight, but I was expecting 80-90. This can be an indicator problem. I'll check that out tomorrow too.
The CHT for #1 seems alittle low, but I guess it's too early to start experimenting with alu-tape?
So: any thoughts folks?
PS: I've not yet been able to reach Brad on his cellphone, but I'll keep trying...
