05-18-2008, 04:09 PM
Wingtips at trailing edge
I've been reviewing the wing construction details on the RV-10 wings on a few builder sites. I am wondering about the area where the onboard trailing edge of the wingtip is near the tip of the aileron.
Is there some filler in the wingtip in that area to close it off and make it rigid? In other words, when you move the aileron up or down, is that area just open?
Happy Landings!
Kevin "PropellerHead" Schlosser
Tooling Up for an RV-10 build.
Relocating to VA. Planning custom home build around RV workshop with wife's blessing!
My Website: www.propellerhead-online.net
RC Model Club: www.jcsportfliers.org
RC Bowling: www.rcbowling.org
05-18-2008, 04:28 PM
JOAT-MON & Moderator
Check your plans and your kit parts. There are formed aluminum 'tip ribs' that you rivet into the wingtips.
Rick Gray in Ohio - Builder Assist Center - 50+ Awards & counting
BRONZE / SILVER & GOLD LINDY AWARD WINNING RV's & Rockets
EAA Oshkosh Homebuilt Judge/Tech Counselor/Flight Advisor / F.A.S.T. Formation Flight Lead
Kitfox/RV4/6/7/8/9/10/12/14?s
6 RV10's
2 Time Sun n Fun Grand Champion
F1 Rocket #1 Oshkosh Gold Lindy Grand Champion!
F1 Rocket #2 :-)
Fastback RV8 Slider
RV14 #2 in progress
53 RV's & Rockets & counting
Whirlwind Prop Dealer
Love my Pitts S-1S
05-18-2008, 09:20 PM
Tip alignment
I have just attached my wing tips. Per previous, the tip is closed out with a rib. Take a hint and don't follow the plans religiously. The flap, aileron and trailing edge all need to be aligned with the flap in the reflex position. Don't match drill the tips until you have set the alignment of the trailing edge properly. I did it per plans and my right tip finished up more than 1/2" below the flap/aileron. If you do nothing, you end up with the tip acting as a mini aileron and a consequent heavy left wing. 10hrs work later and I'm still building up and trimming the trailing edge.
cheers,
Ron
40187 finishing
07-05-2008, 04:51 PM
cheers,
Ron
40187 finishing
I wish I would have had this advice over a year ago! Mine was 3/4" to high. I fixed mine in about four hours not including some minor bondo work and paint. It probably could have been done in less than two if we were by a shop and not at the airport. We came up with a very simple and structurally sound fix. If you need to know how to do it let me know.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
05-01-2009, 07:07 PM
Tip Alingment
I understand that the aileron, flap, trailing edge need to be in a neutral, relaxed position...but I'm a little dense (sometimes more than just a little)..is there a way to be positive that they are in line?..Do you just run a straight edge off the back of the wing with ailerons attached? This seems so simple, I'm afraid I must be missing something.. The flap to neutral, align to aileron with the flap, and then align the tip with the aileron, right?..
Brian K. Morrow
DuBois,Il
N433BC RV-7A Flying
RV-12is EMP in progress!..Official Repeat Offender
"Maintain thy airspeed...Lest the earth arise and smite thee..."
05-01-2009, 09:45 PM
Yep, I think you missed something. The flaps, aileron and wing are set in the reflex position... -3 degrees. This is done by bringing the flaps up to the stops (that should make them -3 Degrees) then aligning the aileron and then the wing tip. I did this with my wings in the stand.....clamped the aileron to the flap and then set the wing tip.
Good luck with the wing tip.....probably because of my lack of skill I had to rework the training edge on both of mine. Not really that hard, just more fiberglass work.....yuck.
Rene' Felker
N423CF RV-10 Flying
05-01-2009, 09:54 PM
I found there wasn't much "adjusting" I could do... the tip just sits in there. One of mine was dead on, but the other is about 1/4" off.
-Rob
Rob Kochman
RV-10, Flying as of March 2011 ( blog)
Paine Field (KPAE)
EAA Chapter 1440
