05-16-2008, 04:49 PM
The debate is resolved
Bombardier has figured out how to resolve the nosegear vs tailwheel debate:
http://www.flickr.com/photos/21003395@N08/2483330336
Martin
Martin Gomez
Redwood City, CA
"My RV-7 is a composite airplane: it's made of aluminum, blood, sweat, and money"
RV-7 Slider QB
05-16-2008, 05:21 PM
The unigear is on the wrong end.
Sorry, I couldn't resist.
05-16-2008, 05:40 PM
fugio ergo sum
Both at once.
TODR the other day mentioned that he has been flying an ASK-21 glider. Like many modern two-seat gliders the ASK-21 normally has both a nose wheel and a tail wheel and a main gear. I'm not sure about the 21 but a lot of these two seaters can use all three wheels on one flight, depending on loading. http://en.wikipedia.org/wiki/Schleicher_ASK_21
My dorky little PW-5 has a main gear, nose wheel, tail wheel, left tip wheel and right tip wheel, for a total of five. Got the bases pretty much covered.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
05-16-2008, 06:27 PM
All corners covered...
...and if you don't balance correctly on the big one, you always have a wheel to fall on, no matter which end of the glider drops....
gil A - with a Mini-Nimbus with only two wheels (and I had to add the tail wheel... ...) -- skids on the tips, and an expensive fiberglas repair if you use the nose...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
05-16-2008, 06:35 PM
fugio ergo sum
Originally Posted by az_gila
...with a Mini-Nimbus with only two wheels (and I had to add the tail wheel...  ...
Nice glider Gil, I had a C model for quite a while. I put a roller-blade wheel on the tail. Great improvement!
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
05-16-2008, 07:54 PM
I love that!
Martin Gomez
Redwood City, CA
RV-7 Slider QB
05-16-2008, 08:42 PM
I didn't know Europa came out with a bigger model.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
