Old 04-27-2008, 07:22 AM
MS19087's Avatar
MS19087 MS19087 is offline
Default Pictures of your Lightspeed 'brain-box" installation
I've check the treads and found no pictures of typical LSI brain box installs. I'm looking at various options but want ti make sure that I select the right place. Current thinking is either mounted in center & top of FW on cabin side OR mounting on ribs between FW and subpanel. Either way, I assume I want the connectors facing side to side. Thanks for you input.
Mark
RV-9A; Sold
RV-14A; Building
2020 =VAF= donor
Old 04-27-2008, 10:18 AM
JoeBlank's Avatar
JoeBlank JoeBlank is offline
Default Firewall Recess
Mine is mounted on the cabin side of the F-601 Firewall Recess. Use 4 screws for mounting and seal the holes with RTV at install. The 2 primary leads to the ignition coils use their own firewall pentration and are not run with other wires due to possible RF. You will also have to T off of your MP line and bring that inside the cabin for the LSE unit. Hope this helps...
Joe Blank
RV-6
IO-320-D1A
Advanced Flight Systems
Van's Aircraft Inc. Technical Support-Retired
EAA Tech Counselor & Flight Advisor
www.westcoastravens.com
Old 04-27-2008, 12:50 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Pics sent
I emailed you pics of LS installations with an attached Zip file about 4.1 Mb. Enjoy
George
Raleigh, NC Area
2020 Dues Paid
Old 04-27-2008, 02:50 PM
AlexPeterson's Avatar
Sorry for the crummy picture, but here is how I did it:
There are two 3/4 angles from the firewall to the sub panel, and the boxes mount to those.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 04-27-2008, 07:51 PM
flion's Avatar
flion flion is offline
Oo! Could I get a copy. I've got IIIs with the flywheel sensor and the manual diagrams and pics aren't really clear how the sensor wires hook up. And I'd also like to see the MP hookup.
Old 04-27-2008, 09:07 PM
qtrmiledan qtrmiledan is offline
Default LSE Info
George- can I have a copy also? Thanks, Danny
Danny B
Baker,La.
RV9A #91137 Flying!!
Old 04-28-2008, 03:32 PM
kentb's Avatar
kentb kentb is offline
Default Don't look at my wiring, but...
Look on the left side of the image.
You can see the black box mounted on the web of the support for the top skin. The image is looking from the FW looking back.
This image is looking from the outboard (right side of the plane). Note the platenut (two showing) in the four corners of the box. Held in place with 4 screws.
Enjoy... Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 04-30-2008, 02:32 PM
DocThrock DocThrock is offline
That's a pic of my dual Lightspeed CDIs mounted on a shelf directly behind my instrument panel on my Rocket. Klaus said it was OK to stack them, just make sure you give them about 1/2 inch breathing room for cooling.
More pics.
Old 04-30-2008, 05:55 PM
Wes Hays's Avatar
Wes Hays Wes Hays is offline
George, If possible, I would also like a copy of the zip file and information.
e-mail is wbhays@verizon.net
Wes Hays
Winters, TX
RV-6A Flying 900+ hrs
RV-7A Fuselage
Old 05-02-2008, 08:05 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Here's a picture of my installation. This is mounted between the firewall and sub-panel. It's hinged at the firewall so I can drop it down for access.
I'm actually set up for dual Lightspeeds even though I plan on running w/ 1 LSE and 1 Mag for at least 100 hours.
If you look closely at the second picture, you can see the #2 brainbox mounted upside down on the bottom of the shelf (it just looks like a black shadow in the pic).
I originally had the brain boxes turned in the opposite direction (d-sub in the rear) but the wires from the crank sensor were too short, so I had to do some re-configuration.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
