Go Back   VAF Forums > RV Firewall Forward Section > Alternative Engines
Old 01-18-2008, 08:21 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Default Auto 4 Bangers for RVs
I was just cruising Bud Warren's site here and see he has a drive for supercharged 205hp Ecotecs now. http://www.geareddrives.com/engines.html
Sounds like a pretty lightweight package.
He is still selling the V8 stuff as well and there is talk of one of the Reno front runners maybe being Chevrolet big block powered next year- Nemesis or Lancair? Should be interesting.
BTW we are about to take delivery of a 405hp LS6 for our V8 EFI/ distributorless ignition engine development program. I'll post our results and dyno numbers in a couple months hopefully. I had great service from: http://www.crateenginedepot.com/ and I'd highly recommend them if you are in need of a GM crate engine.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 01-18-2008, 09:05 PM
TSwezey TSwezey is offline
What are you going to attach it to?
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 01-18-2008, 09:14 PM
CNEJR CNEJR is offline
If I were building an RV10, I would have to seriously consider Bud's setup on the LS1 Chev. I have seen it run and it is sooooooooo smooth. With 350hp it would really tug around a 10.
Chuck Elsey
RV6 Start 7/06- Flying!
N349CE
Old 01-19-2008, 09:47 AM
rv6ejguy's Avatar
It will be on a test stand to validate the new EFI/ ignition setup and be used as a mockup for engineering the crank sensor setup. Going on a dyno after that to look at hp numbers and shoot a video for marketing then- I'll have an LS6 for sale I guess. It has given me sick thoughts of doing a kit for RV10s though. I think with the right drive, weight could be close to that of an IO-540. An EPI, Marcotte or Warren drive would still keep this at about half the cost of a new Lycoming. Performance would be impressive, 260hp at about 4000 rpm -just loafin'.
For Rocket lads, the rumored 600hp 6.2L LS9 would melt the paint and give them a chance to take the world time to climb records.
Old 01-19-2008, 10:06 AM
I have had a couple of rocket/EVO wing builders call me about the LS engines just because they needed a little more nose weight.
As I have been working more and more on the auto conversion and I also think that the combo can be made in mass quantities for less than the Lycosauras. I think one could take Tracy Crooks (yours when you get it done) control system, Bud Warren's PSRU and a stock LS2 and make it work for less than $20,000. The non-off the shelf items right now would be the cowl and the engine mount which could be fabricated by someone. Well, right now, just got to get what I got working right!
Todd
N110TD
Old 01-19-2008, 03:26 PM
djvdb63 djvdb63 is offline
Ross...
Does the supercharger belt on this package make you nervous? I won't even ask DD what he thinks about that.
I couldn't tell from the web site...do you know if Geared Drives PSRU's allow for a traditional oil-driven CS prop? I would assume not...except that the 3blade prop on the Express looks to have Hartzell blades.
Your post prompted me to find the NTSB summary on Bud's Express that went down last October: http://www.ntsb.gov/ntsb/brief.asp?e...06X01740&key=1
The ruptured fuel line points to another hazard of the high-pressure fuel injected systems for aircraft, eh?
Dan
Chicago
RV-9A Empennage
Old 01-19-2008, 03:52 PM
rv6ejguy's Avatar
I'd dump the supercharger and install a turbo personally but I'd have no worries about using an OEM designed and mounted system.
Yes, Bud's PSRUs have hydraulic prop capability as do EPI's and Marcottes and another new one about to be tested so this is no longer a valid beef.
I've said this before, you really have to watch braided stainless hose with aluminum tube elbow fittings. These must be well supported. I prefer steel fittings, they are much stronger and have vastly better fatigue and fire resistance. I doubt if the actual stainless braided hose failed in the middle.
I think a broken fuel line on any aircraft firewall forward is very serious- higher pressures with FI just make it a bit worse. OEMs in the auto world use good old rubber fuel hose (burst rated at 900 psi) and hose clamps for good reason- it is very reliable with billions of hours of proven use. I use this with fire sleeve instead of braided line in most parts of my aircraft.
Todd, if I was doing it all over again, I'd be very tempted to use an LS6 and strive to keep things as light as possible. Looks like 500 lbs. dressed with redrive is quite possible, add maybe 35-40 for rad, scoop and coolant. Use a composite prop and you'd come out about 50 lbs. heavier overall I think than the IO. It is just so attractive to take a new $5K engine, bolt it to a $8-10K PSRU, add another $2-3K of accessories and fly it. If it wears out in 1000 hours, just plug in another longblock for $3K.
Old 01-20-2008, 09:49 PM
Jconard's Avatar
Jconard Jconard is offline
Sounds great...anyone actually done that?
Old 01-21-2008, 05:55 AM
Some of us are working on it but we are also building the planes at the same time. My plane is being painted and the prop and PSRU have to be shipped back to manufacturer for some modifications. In a few years it will be a reality of plug-n-play components for the engine combo's. Right now, everything is more or less in the development/testing stages.
Todd
N110TD
Old 01-21-2008, 10:24 AM
Steve A's Avatar
Steve A Steve A is offline
Default Auto 4 Bangers for RV's
Most people sign off with the plane they are building and what stage they are at. Should we just call you Mr. Negative????
Steve A
RV 7A Finishing
Primed Fairings this Weekend
