Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
Old 01-10-2008, 02:25 PM
AMURRAY's Avatar
AMURRAY AMURRAY is offline
Default INSTALLING AN EFIS IN A RV-6 TIP UP
I never thought I would install an EFIS in my RV. If I want to fly an EFIS I will go to work. Steam gauges are good with me. But these new EFIS, EMS combos are now cheaper than buying all the round gauges. So I'm going to buy one. Now this is my problem. The RV6 tip up has the F645 instrument panel mounting rib right in the line of sight of the pilot. Which is OK for a 6 pack. To mount an EFIS I will have to offset to the center of the panel. I guess I will have to get used to it. My question is how has others dealt with laying out there panel? Pictures would be appreciated.
Aaron
RV6 built and flying
Bearhawk Patrol plans purchased
Old 01-10-2008, 03:17 PM
breister breister is offline
Try playing around with the tool at EPanelBuilder. You can put in an imaginary line in the middle and position various pieces of equipment.
Rather than a single unit, you might consider side-by-sides like the units from Aspen Avionics. They are not in full production yet, but should be soon. You could get nearly the same effect from a pair of vertically mounted Blue Mountain EFIS Sports.
Good luck!
Old 01-10-2008, 03:36 PM
Jim P's Avatar
Jim P Jim P is offline
Unless the -6 tipper is substantially different from the -7, we've usually just cut off the panel rib and moved it outboard a couple inches to accomodate the EFIS.
Jim
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 01-10-2008, 03:49 PM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default EFIS
How about the Dynon D10A......fits in existing hole, or to the right
of the support.
You can even stack two of them and be less than the Aspen.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 01-10-2008, 03:54 PM
Norman CYYJ Norman CYYJ is offline
Cut the offending rib out and displace it to the right and build another rib like it and displace it to the right of the removed rib. This will cure your problem and also add some strength to the panel. I have done several times with good success.
Old 01-10-2008, 04:56 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation I cut it down...
My approach is slightly different.... I cut the left hand brace down so it only captures the lower screw.
I'm not flying yet, but if the panel proves to be too "wiggly" a single rod brace from the EFIS mount bracket to the sub-panel bulkhead will stiffen it up. A single nutplate on the sub-panel should be sufficient for this brace...
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-10-2008, 07:00 PM
Gil you might want to put a support in now and not later it will be easier and won't cut into your flying time. Reason being that you will grab or an other person will grab the panel to steady themselves and it will end up bending while they are getting in or out. Those panel just don't have enough strength in them without the ribs. That is why I went with the extra rib, also I use 1/8 angle around the top instead of the .063.
Your panel is looking good.
Old 01-10-2008, 07:08 PM
Ironflight's Avatar
VAF Moderator / Line Boy
In retrofitting Louise's -6 panel, I ran into exactly the same problem with the rib. because the sub-panel ad already been ...er..."modified" several times, I really didn't have a good place to move and remount the rib to, so just decided to put a D10A on the left side of it, and the D180 on the right. Neither of them is directly in front of the pilot, but it really hasn't bothered me yet on the few hours I've flown it.
If you're building from scratch, I'd move the rib - but it was not a huge deal to work around it.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-10-2008, 09:31 PM
AMURRAY's Avatar
Thanks guys for the great ideas. I guess I will be moving-modifying the rib. I guess I should of planned a little better. I already painted the sub panel and ribs. A little paint touch up will be in my future.
Aaron
Old 01-10-2008, 10:06 PM
scott7A scott7A is offline
I was too lazy to move the rib and mounted the D-180 just to the right of it in my -7. It's obviously not centered, but I find that it's not a big deal and don't really notice it at all. Visibility and readability are excellent, and the buttons are all easily reachable.
Scott
RV-7A N653S
265 Hours
