Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 12-05-2007, 07:08 AM
647jc's Avatar
647jc 647jc is offline
Default Vans Spinner Installation Screws
I am fitting my Vans FB spinner and I see in the instructions Van says you can use round head or CS #8 screws with recessed washers. For the CS screws he says to use a #19 CS to accommodate the recessed washer. To CS deep enough to accommodate the CS washer, you will end up enlarging the screw hole since the FB is not thick enough to really accommodate the CS washer. What have others done regarding this? Is there some other washer that works better, are washers really required, the CS can be made deep enough to accommodate the screw only but that fastening may not be strong enough.
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
Old 12-05-2007, 07:26 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default SPINNER SCREWS
Looks like the best bet is the truss head 8's for this application. I questioned my A/I buddy about this very thing over the weekend, and he seemed to think it was a better choice to install the truss head screws. You could always change over to the C/S screws later if you wished. At sun and fun this year I paid close attention to this issue, and it seems like a 50/50 split in the choice judging from the ships that were on the field. I noticed a few cracks around some of the planes spinner screws regardless of how they were attached. I noticed no smoking screw holes with either, but again they may be out there.
HTH...Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 12-05-2007, 07:30 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
I would definetly use the CS screws and washers. The enlarged countersunk holes (they don't enlargen significantly) will be filled by the washer and it will actually self center itself. I don't recall doing anything special and the holes all came out fine and the washers fit in nicely.
Without the washers, the holes will eventually erode and you will have more repairs to deal with. Loose spinners can get very nasty.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 12-05-2007, 07:58 AM
JonJay's Avatar
JonJay JonJay is offline
Default This has not been my experience
Roberta
I used truss head screws on my 6, only 80 hours on them, but no problems. My Bucker spinner has truss screws as well, well over 500 hours on them, no issues.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Ironflight's Avatar
VAF Moderator / Line Boy
I concur with Roberta - I like the look of the countersunk screws in the washers, and the hole enlargement is really a non-issue,as the washer and screw center themselves. In fact, that might actually help to relieve pre-load and stress - kind of like a floating nut plate. Anything you can do to relieve stress out there is a plus!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 12-05-2007, 08:36 AM
McFly's Avatar
McFly McFly is offline
Default Regardless of screw type
Regardless of screw type put a thin bead of RTV on both bulkheads to insure that the spinner gets locked in place. Some people use Proseal to cure spinner movement, the RTV is more of a preventative measure. Good luck.
Hugh
Northern California
RV-7 Flying
Old 12-05-2007, 04:43 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default Disagree with RTV/Proseal on Spinner
Those of us with wooden or wood+composite props have to check torque a few times a year so I think any kind of adhesive would be the wrong idea. Or did I misunderstand you?
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 12-05-2007, 05:07 PM
McFly's Avatar
I have a composite prop which is subject to being retorqued and that is the exact reason I went with RTV rather than Proseal as is sometimes suggested. The RTV does not provide a strong enough bond to hinder spinner removal (well okay a little bit) but it fills voids and prevents movement.
My spinner started to show signs of movement at about 10 hours maybe less. I checked the spinner/bulkhead interfacefor voids but found none. I tried a thin coating of RTV on the bulkheads at the suggestion of an AI bud. It stopped all movement.
When reinstalling the spinner, I just rub off the old RTV with my fingers and put on a new layer.
This has been my experiece anyway. Good luck.
Hugh
Northern California
RV-7 Flying
Old 12-21-2007, 01:37 AM
Default Flat head screws, countersunk spinner holes, dimple washers, no seal
Hartzell C/S non blended airfoil - Flat head screws, countersunk spinner holes, dimple washers, no seal, no problem. Lube the prop hub at annual. Approximately 400 hrs on airplane.
Bob Axsom
Old 12-21-2007, 08:22 PM
Wes Hays's Avatar
Wes Hays Wes Hays is offline
Same as Bob, 800 hrs and no problems at all with the spinner, screws, washers, etx. Just lucky?
Wes Hays
Winters, TX
RV-6A Flying 900+ hrs
RV-7A Fuselage
