11-08-2007, 06:55 AM
Run up Mag drop - one mag and one electronic
What are you seeing on your run up when you have one mag and one electronic ignition?
What RPM are you using for the test?
For me, at high RPM's the drop is greater when I turn off the mag. At low RPM's it is reversed.
Mark Scoggins
Charlotte, NC
RV-6 bought,flown and sold.
Rv-4 bought, flown and sold.
11-08-2007, 07:56 AM
runup data point
Hi,
I have an o-320 in my 9A. Left side is mag right side is lightspeed
I do my test at 1600 RPM
Mag drop is 20 to 30 RPM.
Electronic drip is about 70 RPM.
Don't know if that is good or bad, but have 220 hours on since march and never had a problem.
Duane
Duane Wilson
RV9A. Built, flew 1000 hours, Sold
RV10 Built, flying 330 hours so far.
Central Oregon
11-08-2007, 05:59 PM
IO-360 A1A 200hp
I test at 1900 rpm.
0-10 drop with Mag off.
30-50 drop with EI off. I run an electoair on the right side, with a Hall effect digital RPM display.
Dave Halasi-Kun
RV-7 N98HK
Reason: forgot a detail...
11-08-2007, 06:14 PM
1900 RPM ?
Wow, 1900 RPM would be almost full power with my fixed pitch sensenich prop. I show 24" MP at 1800 RPM. That speed gives 125 drop when I turn off the mag. Half that when I turn off the EI.
You must have a C/S prop?
Mark Scoggins
Charlotte, NC
11-14-2007, 09:39 PM
Electronic Ign Mag drop
Hi Gang,
I have the IO360 CS prop with one impulse Mag and one LightSpeed ignition.
I believe that Klaus says in his specs to expect 150-200 rpm drop when selecting the mag.
I get 0-10 drop on the Plasma II and I get 100-150 drop on the mag.
FYI
Don
RV 7 ECi Titan EX IO360
11-14-2007, 10:39 PM
I have one ElectroAir EI & one Slick mag. I use 1700 rpm with my 360 & C/S prop. Here's what I see...
Mag off: 0-20 rpm drop
EI off: 75-150 rpm drop (usually about 125)
11-15-2007, 07:06 AM
I have a 0-360 with one slick MAG and one lightspeed, I see a 30 rpm drop with just the lightspeed on and I see 50rpm drop when running on just the mag.
All the Best ;-)
RV-8
RV-9 once the kids are older
11-15-2007, 08:26 AM
I have a 0-360 with one slick MAG and one Lightspeed. I drop about 30 RPM on each system.
Hugh
Northern California
RV-7 Flying
11-15-2007, 09:13 AM
ARE YOU SURE YOU'R TURNING OFF THE MAG!
I have a 320 fp. mag on left and a LS on the right. At 1600 rpm, when I shut off the MAG..... no change. When I shut off the LS, I see a 100 rpm drop.
At 800 rpm, IT IS REVERSED!
11-15-2007, 09:57 AM
Eci 0360/180--FP Catto
Mag on Left, LS PIII on Right
Mag check at 1600rpm gives:
10-20 rpm drop when mag switched off
40-70 rpm drop when EI switched off
db
Dave B.
RV9a/ECiIO360/James Cowl/WW RV200 Prop
Flying since 3/06 and still smiling!!!
