Old 10-22-2007, 10:20 AM
A6PILOT A6PILOT is offline
Default Tach indicator problems
I just switched from LASAR to Slick mags and the RPM indicator shows about 1/2 the actual RPM on the VM1000. The transducer is the correct one for Slick mags P/N 3010005. I have the transducer mounted in the lower vent hole of the Model number 4370 Slick (Non Impulse coupled left mag) Before I purchase another transducer, I wonder if anyone has run into a similar problem?
Steve Richmond/Corsicana, TX/RV8 Flying /FFI, Falcon Flight
Old 10-22-2007, 06:02 PM
John Collier John Collier is offline
Default VM1000 RPM Setup?
I'm not familiar with the VM1000s setup...but on the Dynon you must set a pulses per revolution depending on your tachometer source - maybe you need to check this on the VM1000 since your tach source changed?
John Collier
RV8
N774BC
Niceville, FL
Old 10-22-2007, 07:10 PM
N402RH's Avatar
N402RH N402RH is offline
The Slick mag has half the number of pulses as the Lasar, you need to change the setting in the VM1000.
Rob Hickman
N401RH RV-4
Old 10-22-2007, 07:43 PM
I talked to a tech rep today and he explained how to change the jumper in the data processing unit to get the correct readout. Thanks for the responses - problem solved.
