Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
09-25-2022, 04:52 PM
Baffling Ramp Corner
I'm trying to close up the last egregious gaps in my baffling. This is an older RV-6 and I have not been able to find any good pictures of how others have handled the corners of the ramp on the lower cowling..
Mine looks like this:
If I try to extend the baffling on the curve of the lower cowl. it will not sit on the rather square aluminum corner. All suggestions and photos of how to handle this area welcome.
Thanks in advance!
Cheers, Sean
RV6, Flying C-GOFG
CLA4 - Holland Landing
Toronto ON
Donated to December 2023
09-25-2022, 05:38 PM
There is a baffle part that is missing on yours - 2 actually. They are called conical gussets. You make them out of .032. Start with a piece of stiff paper to get the size and shape right and then use that as a template. The left and right conical gussets are not the same size.
SH
RV6/2001 built 2000/sold 2005
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019/sold2021
RV6/August 2022 build - Flying
Cincinnati, OH/KHAO
JAN2022
09-25-2022, 05:44 PM
Here’s a couple pics of mine, recently completed:
SH
Cincinnati, OH/KHAO
JAN2022
09-25-2022, 10:08 PM
Thanks!
Hey Scott,
Thanks a bunch for both the photos and the drawing references. I have a suspicion that my aluminium side baffle to lower cowling gap is too large for the stock solution but that absolutely points me in the right direction for a fix.
Cheers, Sean
RV6, Flying C-GOFG
Toronto ON
09-26-2022, 05:59 AM
On my -4
I curved the inboard lower seal upward and overlapped the seal that's on the forward baffle. takes a little finesse when installing lower cowl, but it seals the area completely.
Bill E.
RV-4/N76WE
8A7 / Advance NC
09-26-2022, 06:40 AM
Thanks Bill. My inboard corner is pretty good but I was contemplating replacing the seal in that area so that certainly helps.
Cheers, Sean
RV6, Flying C-GOFG
Toronto ON
09-27-2022, 05:21 AM
The outboard side
Here is my outboard side solution. I made small curved aluminum corners on my ramps, and the seals extend out over them. Still a small gap evident in the picture, but I didn't feel like cutting another seal piece!.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Thread Tools |
Display Modes |
