VAF on Twitter:
@VansAirForceNet
Go Back   VAF Forums > Education > Instrument Flight Rules
View Poll Results: Is a Marker Beacon Receiver Necessary?
No. Not necessary anywhere. 18 66.67%
Not necessary in the US, but necessary elsewhere. 0 0%
Only necessary if executing an ILS approach without GPS overlay 5 18.52%
Who knows? 4 14.81%
Voters: 27. You may not vote on this poll
Old 09-15-2022, 03:20 PM
1001001's Avatar
1001001 1001001 is offline
Default Poll: Any Reason to Install Marker Beacon Receiver/Antenna?
What's your informed opinion? Is there any reason to install a marker beacon antenna and receiver? Any implications for international flight under IFR if your airplane is not equipped with a MB receiver?
It seems most instrument approaches now don't need one if an IFR approved GPS navigator is installed. What happens if GPS is out and you need to do an ILS? Is it legal to begin such an approach without either GPS or a functional Marker Beacon?
Some sources I've found have suggested it's not necessary, but none of them seem to be authoritative.
Old 09-15-2022, 03:35 PM
jneves's Avatar
jneves jneves is offline
Some good reading on the subject of Marker Beacons.
https://www.pgaafly.com/post/marker-...who-needs-them
Johnny
N455DM - RV-6A - Bought Flying - 2021
Tip Up Canopy
IO-360-A2B
FP 66" Catta 3 blade Carbon
IFR - 2 Garmin G5s - 430W - Aera 760 - GFC500
JPI EMS-350 to monitor the temps
N89WD - Flight Design CTSW - Sold 2021
2022 Donation Happily Made!
Old 09-15-2022, 04:35 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
On an ILS, IIRC, you need to identify the FAF and that used to be done with the Outer Marker -- but other ways work, also.
For an anecdotal answer, check out how many audio panels these days do and how many don't have a marker beacon receiver. Then check all the ILS approaches in your area and see how many have Outer Markers...
This is the long way of saying no.
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
Old 09-15-2022, 05:17 PM
BobTurner BobTurner is online now
Originally Posted by Ed_Wischmeyer View Post
On an ILS, IIRC, you need to identify the FAF and that used to be done with the Outer Marker -- but other ways work, also….
Note that the MB was a legally required sanity check, that the GS was operating properly. In practice, it’s easy to shoot the ILS without MB (but maybe not legal or wise). LOC approach, that’s different.
Both my home field and nearby KSCK have removed MBs/compass locators. At LVK they now use a DME fix for the FAF, so if gps goes down I cannot legally shoot the ILS (I don’t have a DME). But over at SCK a VOR cross-fix is now used to determine the FAF. Since I have a single SL-30 nav radio which can multiplex both the primary and standby nav signals, it goes like this: Loc/GS displayed (GRT Hx) as primary nav signals on the HSI display; cross fix VOR displayed around the HSI as an RMI bearing pointer. It’s actually pretty slick.
Answer to OP question: No, I have no MB receiver.
Old 09-15-2022, 05:29 PM
RV6_flyer's Avatar
My RV-6 first flew September 17, 1997 with an installed marker beacon receiver and antenna. I have flown the aircraft IFR. In the almost 25-years, the marker beacon was not NEEDED.
Gary A. Sobek
NC25 RV-6
Flying
3,500+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 09-15-2022, 05:56 PM
Carl Froehlich's Avatar
The issue I have is PS Engineering’s very nice PDA 360EX audio panel I put into th the RV-8 (no marker beacon) seems to now be discontinued. I assume the replacement for the PDA 360EX is the certified PMA450C, but pricey even without the marker beacon. Too bad.
But if you do install a marker beacon receiver do not waste money on an antenna. A ~36” piece of wire that is suspended under the engine works just fine. Connect the wire to a BNC bulkhead connector on the firewall, then to the marker beacon receiver. That is what I did in the RV-10. I know it works as I get the MB when flying over a field at altitude. Never used it for an approach however.
Carl
Old 09-15-2022, 07:38 PM
1001001's Avatar
I actually did come across that one in my searching on the topic. It seems pretty flatly stated and well documented, but it's not an "authoritative" source.
I have flown a number of ILS approaches in the area here and in other states where the various markers are out of service and there's no particular NOTAM that I can find that mentions requiring a GPS overlay or whatever, so I'm leaning toward the "Marker receiver is not necessary" camp.
But I wanted to hear what people here have done.
Carl, if I were to install one, I was going to do exactly what you suggested, with the wire (but placed in one of the wing root fairings). Not sure I'll bother.
Old 09-15-2022, 08:29 PM
larryMar larryMar is offline
The fleet of 737-800 and max that my x-employer flys international and domestic does not have marker beacons..... just a reference point
