VAF on Twitter:
@VansAirForceNet
  #11
Old 08-28-2022, 07:10 AM
Larry DeCamp Larry DeCamp is offline
Default Carbon/glass lamination ?
Several reference above about combining glass and carbon. Long ago The Horton School of composites made the point the thermal expansion rates are significantly different.
So, is it OK to combine these materials in a layup ?
Larry DeCamp
RV3B sold
RV-4 fastback in process w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 08-28-2022, 09:03 AM
N82VM N82VM is offline
FWIW,
Weight of Van’s gray fiberglass parts in oz.
Emp and Wing Tips
1) 2.4oz VS-809
2) 2.7oz each total 5.4oz HS-615
3) 10.2oz R-411 W/L
4) 4.9oz R-809
5) 4.7oz each total 9.4oz E-612
6) 71.9oz L Wing tip
7) 75.2oz R Wing tip
Total 179.4oz or 10.212lbs
Anyone has a cowl please add the data point for weight. What color , pink, green etc.
Anyone with canopy skirts add data point for weight too.
Tail and wings really isn’t much weight, Carbon saves 15%. A possible 1.5 lbs to be saved on tail/wing. I agree it all adds up, but some may be more effective than others.
Con
Fiberglass is required on wing tips if you use an archer antenna. At 15% weight savings you’re trading 22oz for the loss of ability to use an archer antenna.
Possible Pro/Con
Effects of reduced weight of tail parts and more/less counter weight required? Perhaps someone could answer if you’d need more or less counter weight.
Cowl might be the most beneficial part to make weight savings. I’d assume it’s a substantial weight so a few lbs might be saved on the nose where CG effect may be an advantage depending on your configuration.
RV-8A Project
2022 Dues Paid
Old 08-28-2022, 09:14 AM
BillL's Avatar
BillL BillL is offline
Originally Posted by Allan Stern View Post
Where or who is a good supply of carbon cloth or some 4” carbon tape?
Want to make up a part in carbon fiber and fiberglass.
Allan Stern
Paid 2022
RV 14A
Since you are in Florida, try https://www.uscomposites.com
Bill
RV-7
Old 08-29-2022, 11:39 AM
pacmanmp@gmail.com pacmanmp@gmail.com is offline
This is just for looks not weight for me
Matt
Project RV-8a
